Old 06-08-2008, 05:47 PM   #1
Lothlorian's Avatar
Loganville , Georgia
Removing airstream radio from 73 Overlander
My radio is a factory radio. I can see that there are two rivets holding a bracket in the back which I will drill. I see two rivets or screws that are coming from above through the cabinet and into the radio. If I remove the two rivets underneath and use my Reciprocating Saw to cut the rivets will the radio come out? How did you get your 1970's radio out? I want to upgrade with all new electronics.
You can see my radio in the picture I posted.
SIU Bound
Brian
Name:	Primed front end.JPG
Lothlorian is offline   Reply With Quote
Old 06-08-2008, 06:46 PM   #2
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Brian,
On my 72, 4 screws and the radio is out. There are screws at the back, where you say you have rivets on the bracket, and screws on the sides of the box that houses the radio. They are near the top of the vertical supports that form the sides. One on either side. I overlooked the ones on the sides at first, the heads are brown and just blended in with the brown inside of the storage compartments.
BTW, my radio compartment and central control panel look exactly like yours but as we all know it may be attached completely different.
Good luck, TB
tinbender is offline   Reply With Quote
Old 06-08-2008, 06:59 PM   #3
cameront120's Avatar
1972 25' Tradewind
Looks the same as my 72 Tradewind. I'm keeping the stereo, however, because there is something satisfying about having the option to play 8-track tapes!
North Vancouver, BC
Old 06-08-2008, 07:41 PM   #4
ibgl6's Avatar
Southport (Panama City) , Florida
Send a message via AIM to ibgl6
My 73 has a cassette?? I wonder if it was changed? I musta been cause I dont think cassettes had been invented yet?? Not sure though was but a wee little tike in 1973 haha ...SAM
Your Friend Sam In (Southport) Panama City Florida
Air#15607 TAC FL-2
Good Sam (LifeTime Member)
ibgl6 is offline   Reply With Quote
Old 06-08-2008, 07:56 PM   #5
1972 25' Tradewind
There certainly were cassette decks in 1973. My father's Volkswagen had one. I think it was a Philips.
North Vancouver, BC
Old 06-08-2008, 08:09 PM   #6
Lothlorian's Avatar
I want to put in a AM/FM, CD, and weather radio. I have a flat panel TV my kids bought for me which I will put on a Wall mount. I will install a DVD player.
Thanks for the help. I am going to pull that radio and I did not want to ruing anything.
SIU Bound
Brian
Old 06-08-2008, 08:26 PM   #7
1972 25' Tradewind
If you have an ipod, you may want to hardwire a cable for that while you're at it. Very handy.
North Vancouver, BC
Old 06-08-2008, 08:47 PM   #8
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
I had a '72 at one time and replaced the radio. I don't recall exactly how it was attached, but there were screws you could get to by removing the control panel from above. The control panel comes out with a screw on each side, iirc. Then you can reach in from above and deal with the radio mounting setup. Good luck!
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 06-09-2008, 01:52 PM   #9
Lothlorian's Avatar
I dropped the radio only to find mass amounts of wires back there. I am afraid to cut them because I do not know what they all go to.
SIU Bound
Brian
Old 06-09-2008, 02:01 PM   #10
DPeakMD's Avatar
1975 23' Safari
Franklin , Indiana
There are a lot of wires! You'll basically have 3 different categories:
  1. Power & Ground
  2. Antenna
  3. Pairs of wires to each speaker
If you have a tape player, then there are more for that!
They are all listed in the Service Manual as to color and function.
Your replacement stereo will come with a harness. Just match up all of the different wires in the pigtail and you're set to go. The antenna coaxes have changed somewhat through the years. Take a look at yours for size. You may have to buy a converter to use with newer stereo head units.
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
Old 06-09-2008, 02:03 PM   #11
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
You should have 4 speakers 2 wires each,a + and a - ,any more than that,i have no idea. Dave
easyride is offline   Reply With Quote
Old 06-09-2008, 05:28 PM   #12
Lothlorian's Avatar
Now that I have the radio out I am evaluating the antenna. The Motorola works but I only get one station. Should I change out the antenna?
SIU Bound
Brian
Old 06-09-2008, 07:26 PM   #13
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
What antenna do you have? Does it feed back over to the television antenna, or is there a seperate antenna for the radio?
I have the wiring colors if you need them.
www.nesa.org
Air No. 6427
Old 06-09-2008, 07:28 PM   #14
DPeakMD's Avatar
1975 23' Safari
Franklin , Indiana
Make sure you have the antenna extended all the way first! (Grab the little ball on top and pull out all three sections) Also, the newer tuners are a lot better receivers than your old Motorola, so I wouldn't make any conclusions until you confirm reception with the new radio. Both of my 70's vintage antennas have worked well. The original Motorola radio in my '72 could not hold a station anymore and was very 'deaf' even with the "distance" function engaged.
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
Looking for 1967 Overlander radio and TV antenna bighowdytex Audio, Video & TV 8 12-17-2015 04:22 PM
Removing a radio/8-track unit for repair or replacement lbf78SvgnInt31 1974 - 1979 Sovereign 9 11-30-2012 04:08 PM
Removing interior skin-Overlander Zeppelinium General Interior Topics 15 11-18-2008 10:25 AM
72 overlander radio speakers emanon25 Electrical - Systems, Generators, Batteries & Solar 6 09-18-2004 12:18 PM
Removing window frames..'68 Overlander???? fly2havefun Windows & Screens 3 05-18-2004 06:14 PM
