Old 08-29-2015, 07:24 AM   #1
white laker's Avatar
2002 31' Classic
lanark , Ontario
Rear Teelevision cable rear outlet
Hi Folks
for the life of me I cannot figure out the cable/coax wiring in my 2002 31 Classic. I have over the air reception from the front cable port but when I try to plug into the rear coax I cant get a signal. I pulled the cover off in the front and there were three cables. One input and two outputs. All connections were tight. There was also a small circuit board involved, bot sure what it does.
Went to the rear coax and pulled the cover. My manual shows a single coax which would make sense to me but again I found a small circuir board and TWO coax cables. I cannot get a signal from either cable.
SOoooooooooo..............
Any ideas what the circuit boards are?
Any ideas why I would have two coax cables in the rear?
I can use a multi-meter but dont know what to test or what 'normal' is. Any ideas?
I find the manual remind me of my younger days fixing cars with "Clymer" shop manuals. Close but no cigar!
any help would be appreciated.
Pete
Pete Crook
"Put it all behind you!"
white laker is offline   Reply With Quote
Installing whole trailer inverter outlet like the shore cable richinny Electrical - Systems, Generators, Batteries & Solar 20 08-04-2015 11:57 AM
Cable only comes through 1 interior outlet k0irl Audio, Video & TV 0 10-12-2014 08:18 PM
Coaxial cable outlet - passenger side Ellisu2015 Sprinter and B-van Forum 3 09-01-2014 06:49 PM
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 08:16 AM
Exterior TV Cable Outlet McDonalds Audio, Video & TV 3 06-13-2011 09:51 PM
