Old 12-12-2005, 06:37 PM   #1
1991 25' Excella
SF Bay Area , California
Radio Power in 1991 Excella 25'
Can anyone tell me if there is a switch for the radio to work on AC power rather than the battery?
aeriqua is offline   Reply With Quote
Old 12-12-2005, 06:42 PM   #2
bill benton's Avatar
Mansfield , Texas
Ours is the same type that is in a car. If your charger is on even if your batteries are dead, it should still work.
bill benton is offline   Reply With Quote
Old 12-20-2005, 04:18 AM   #3
1993 29' Excella
Jonesboro , Louisiana
This is a dc powered radior and will not work on ac. The charger will supply the necesary dc even if the battery is missing but it is not recommmeded as it will affect the quality of the audio of the radio. If it doesn't work with a battery in place and or the charger plugged in then I think you have a radio problem.
James Schmidt
29 ft Excello 1000
97 Expedition/Hensley Hitch/
McKesh mirrors
James Schmidt is offline   Reply With Quote
Old 12-25-2005, 12:23 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
For AC operation you need a 'home type' stereo unit, not the mobile 12VDC units that come from the factory. There are no car-type stereos that I know of that will also work on 120 VAC. Of course, you could use an inverter connected to your batteries to produce 120VAC if you aren't plugged in and are dry camping, but that would be kind of redundant IMO.
If your 12V stereo is not working, check the fuses and ground connections. 90% of the problems start there.
Excella 1991 29' Fritz 1990 - 1993 Excella 6 08-21-2013 08:52 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
power boosters John Our Community 18 11-19-2002 03:54 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
78 Excella 500 davidz71 Our Community 2 10-17-2002 01:11 PM
