Old 10-14-2014, 06:32 PM   #1
2017 25' Flying Cloud
w.springfield , Massachusetts
Radio comes on with interior lights ?
I figure i'm missing something ,but can't find out what from the manual . When I turn on the battery from storage to use switch ,Then the interior lights ,the Sony radio turns on ? I have 2014 20 foot flying cloud with a Sony DSL-s310btx radio . Am I missing a preset somehow ? Thanks in advance for any advice !
mazoolah is offline   Reply With Quote
Old 10-14-2014, 07:04 PM   #2
TCwheels's Avatar
2011 20' Flying Cloud
Traverse City , Michigan
My NTU 2011 FC20 with the Sony radio does the same thing. Just picked it up Saturday and noticed this. I doubled checked that the radio was off and it turned on when switched from storage to use.
WBCCI #7246
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 10-14-2014, 07:08 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Sounds like the radio got wired to the wrong side of the light switch.
Not to say it should be wired to the switch at all but rather to a positive source. Someone took a short cut while wiring things.
Now you could turn the radio off with the volume control on the radio but you could never play the radio in the dark.
2004 Excursion 4x4
Old 10-14-2014, 07:17 PM   #4
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Mine is the same. Radio turns on when you switch to use. Even when lights are off. I've gotten used to turning it off any time we plug in.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-14-2014, 07:21 PM   #5
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
When you use the battery disconnect, it's basically the same as actually disconnecting. When you reconnect a disconnected battery, the radio will always turn on. It does it in my 2014 25ft as well.
George
gandttimes is offline   Reply With Quote
Old 10-14-2014, 07:47 PM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Same here. Critical to remember to turn it off. Definitely not a faulty switch - this is how it's set up.
Old 10-14-2014, 08:14 PM   #7
waltb's Avatar
2014 25' Flying Cloud
San Luis Obispo , California
Send a message via AIM to waltb Send a message via Skype™ to waltb
My 2014 FC and my 2010 FC did the same thing.
2014 Flying Cloud - 25' RB
2016 Tundra
Air# 42643; WBCCI# 3884
waltb is offline   Reply With Quote
Old 10-15-2014, 05:20 AM   #8
"loud old man groan " ha! ok so I live with it .Or has anybody tried a extra on off switch for the radio ?
Old 10-15-2014, 05:39 AM   #9
Wayne&Sam's Avatar
Cuddebackville , New York
Images: 21
Pressing the off button really only puts it in a standby mode, with the subwoofer still on. Press and HOLD the off button until the display goes completely off- no clock or anything. This also shuts off the subwoofer. Next time you power up the trailer, it will still be off.
2012 Dodge Durango Hemi/AWD
Old 10-15-2014, 06:17 AM   #10
I definitely hold it down til black (and then some with the frustration factored in ,ha! ) no lights ,clock ,nothing . but it still does it .Mine doesn't have a sub woofer ,tho.
Old 10-15-2014, 06:35 AM   #11
Wayne&Sam's Avatar
Images: 21
Weird.
Old 10-15-2014, 08:15 AM   #12
richw46's Avatar
Lexington , Kentucky
My Sony in my 2006 gets power to the display but no source is selected. I think it's just the function of the radio that when it gets power it comes on because the separate power line for memory isn't connected. When mine comes on all of the presets are gone, the clock isn't set and the last input isn't set.
On most car radios there is a separate wire that can be connected to a 12v source that will allow it to remember its last position and all the presets. Find that line, add an inline fuse and put it on a constant 12v battery connection and that will solve the problem.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 10-15-2014, 08:33 AM   #13
Gainesville , Florida
I never used the radio. Just cut the wires. Lazy arse solution, but works. Seriously, that is strange that it turns on, has to be a way to defeat this. Jim
Old 10-15-2014, 08:46 AM   #14
richw46's Avatar
Sony eSupport - DSX-S310BTX - Support
According to the installation instructions, connect the yellow wire to a full time 12v source with an inline fuse. Either your yellow wire is connected to the red wire or it's not connected to anything
RED WIRE
- To the +12 V power terminal which is energized
in the accessory position of the ignition switch
Notes
-- If there is no accessory position, connect to the +12 V power
(battery) terminal which is energized at all times.
Be sure to connect the black ground (earth) lead to a metal
surface of the car first.
YELLOW WIRE - To the +12 V power terminal which is energized
at all times
Be sure to connect the black ground (earth) lead to a metal surface
of the car first.
Memory hold connection
When the yellow power supply lead is connected, power will always be
supplied to the memory circuit even when the ignition switch is turned
off.
-Rich
Rich & Yvonne
2004 4Runner SE
Radio Speakers but no Radio 1969 ???? tdoescher 1965-1969 Sovereign 13 04-21-2015 01:17 PM
Cable only comes through 1 interior outlet k0irl Audio, Video & TV 0 10-12-2014 08:18 PM
cb radio, cassette radio jagcb750 Classic Motorhomes 14 04-19-2012 02:32 PM
Now comes the next fun phase: discovery. jpurdy General Motorhome Topics 3 02-16-2003 06:39 PM
