Old 05-27-2009, 06:54 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Radio Antenna Nightmare
I have had everything go wrong with the radio antenna that I possibly could. First, although I had it propped out of my way while polishing, I nicked it with the polisher & it went flying. Put a small dent & scratch in the section that it's mounted and cracked off. I actually had a spare one in my basement.
This afternoon, I looked for advise on how to change it out. I found that you can get at it through the speaker in the trailer. I found the wire immediately. I cut the old antenna off, but couldn't find any sort of connection for a new one. Off to Radio Shack. They had nothing. I thought maybe I could splice it to the old one. No go. Went to Best Buy & found an extention for an antenna. Hooked it up to the end by the radio & duct taped it up good. Pulled on the end by the antenna to feed the new part through. Well, I found the connection. Way up in the endcap it was connected. Short of taking the entire endcap apart, how in the world can I get the wire through the wall, behind the endcap & to the back of the radio? Anyone? My husband was beginning to take the endcap apart, but I told him the Forum people would know a better way. Please, don't let me down!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 05-27-2009, 07:12 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Becky, it "was connected?" does that mean the two halves pulled apart?
MAYBE you can run a vinyl hose (like a vinyl water line) up into the wall, stick the antenna wire inside the hose, and shove the hose into the wall. When it gets where you can grab it, pull the old antenna wire out through the hose, and slide the new antenna wire up into the hose. Use silicone slip-spray on the antenna and inside the hose.
Plan B would be to relocate the radio near where the antenna is mounted, it may be less trouble...
Old 05-27-2009, 07:30 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
Yes, the two halves pulled apart. I couldn't tell there were two halves (not that I could have reached the connection). I don't have any old wire in the wall. I have the wire from the stereo that goes up into the endcap oblivion. I might have to make a hole in the inside of the endcap cabinet & maybe use your idea with the hose to run the new wire up to the endcap section from the wall.
Becky
1964 Bambi II
1988 Avion 32S
Old 05-27-2009, 07:40 PM   #4
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
What about a concealed antenna,just laying behind the stereo.Then you could leave your new antenna mounted as a dummy.Dave
easyride is offline   Reply With Quote
Old 05-27-2009, 07:44 PM   #5
Becky B.'s Avatar
1964 17' Bambi II
I would do that as a last resort, but the radio worked really well with the antenna. I'm so ticked at myself!
Becky
1964 Bambi II
1988 Avion 32S
Old 05-27-2009, 08:28 PM   #6
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
How about using a stiff wire, like from a wire coat hanger, as a probe? Poke it though one hole, and try to fish it in the direction you need to go to. If you can get the coat hanger through the space, and find the end of it, then you can tape the antenna wire to it. Tape it really well - use black electrical tape instead of duct tape. You may need to fish a coat hanger from both ends. Use a pair of pliers to make small hooks in the ends of each hanger, and try to snag one with the other and pull it the rest of the way. I've done this many times fishing wires through my house walls. Patience is a virtue in this...
Chris
Old 05-28-2009, 05:09 AM   #7
Becky B.'s Avatar
1964 17' Bambi II
The area the wire has to travel is probably 4 feet. It comes out a hole that is the size of a quarter, along with speaker wires. Does anyone think it's feasible to take the speaker wire off & pull it through with that? Does anyone know if there is a connection in the speaker wire somewhere in the back of the endcap? I wouldn't want the same thing to happen with the speaker wire.
Becky
1964 Bambi II
1988 Avion 32S
Old 05-28-2009, 05:34 AM   #8
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Try A Wire Fish
Becky,
Do you know any electricians that might let you borrow a Steel Fish Tape? They come in handy while trying to fish wires through walls and are better and longer than wire hangers. They can be had at the big box stores or most hardware stores.
If you need a replacement antenna, Out Of Doors Mart has them and the parts...
Radio Antenna 077069-01-000 [44-UP21] - $18.95 : ODMRV , Out-of-Doors Mart
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 05-28-2009, 05:39 AM   #9
DEITZ645's Avatar
Becky,
If you try pulling the antenna wire through with the speaker wires make sure you also tape some string to the antenna and speaker wire so you can pull the speaker wire back through with the string. The only thing I worry about is that the speaker wires may have been tie wrapped to the skin or a rib which will make it impossible to pull the antenna wire back to the radio via the speaker wires.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 05-28-2009, 08:06 AM   #10
Becky B.'s Avatar
1964 17' Bambi II
I took a few pictures of the situation. (no, the long dent is from the window protector, not the antenna--that's the small one to the right). The wires coming out of the hole are from the antenna (thick one) and the speaker wires (thin green & black) The antenna wire has to go from the hole to the back of the radio--all behind wall & endcap. I thought about taking out a section of the wall to the left of the window. I'd only have to remove a couple of rivets & some screws. I'm at work right now, so maybe tonight I'll get at it.
Name:	radio antenna 5.jpg
ID:	81023   Click image for larger version
Name:	radio antenna 1.jpg
Name:	radio antenna 2.jpg
ID:	81025   Click image for larger version
Name:	radio antenna 3.jpg
Name:	radio antenna 4.jpg
Becky
1964 Bambi II
1988 Avion 32S
Old 05-29-2009, 06:18 AM   #11
Becky B.'s Avatar
1964 17' Bambi II
Ok, so here's what I did. I drilled a hole inside the cabinet so I didn't have to fish for such a long way with the coathanger. I then removed the window frame & rivets by the speaker hole where the wires go up to the endcap. I could feel with my finger into the hole. I fed the coathanger from the hole I drilled & actually got ahold of if through the quarter sized hole! I pulled it down & attached the antenna wire to it & a string just in case the wire came off. It all came through the other end! Yeah! I put everything back together & have a connection under the speaker, just in case this ever happens again!
Name:	radio antenna 7.jpg
ID:	81087   Click image for larger version
Name:	radio antenna 6.jpg
Name:	radio antenna 8.jpg
ID:	81089   Click image for larger version
Name:	radio antenna 10.jpg
Name:	radio antenna 11.jpg
Becky
1964 Bambi II
1988 Avion 32S
Old 05-29-2009, 07:16 AM   #12
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
nice!
Slick!
Old 05-29-2009, 10:27 AM   #13
Ottawa , ON
Way to go, Becky!
Old 08-10-2009, 01:02 PM   #14
Becky B.'s Avatar
1964 17' Bambi II
Okay, so it's not even 3 months since I put this new antenna on. It's already rusty! I bought it off of ebay last year (needed another part off of it), so it's too late to return it. Talked to the guy I bought it from & told him it was a piece of junk! He directed me to the manufacturer. Well, I'm not going through all that trouble for a $15 antenna. I guess I'll give one of the regular Airstream guys a call & order an original parts one for twice or three times the price, unless someone has a better suggestion!
Becky
1964 Bambi II
1988 Avion 32S
Radio Antenna for 1962 FC smcpheters 1960 - 1963 Flying Cloud 8 08-18-2018 11:54 AM
Radio Antenna sovereignrwe Audio, Video & TV 8 12-15-2008 02:21 PM
Radio Antenna rochar3 Exterior Restoration Forum 2 09-22-2008 09:53 AM
What kind of CB radio/antenna Stream 1529 Tow Vehicles 46 04-18-2008 03:38 PM
Radio Antenna niftypkg Phone, CB & Ham Radio 5 02-17-2007 03:20 PM
