Old 08-10-2009, 01:28 PM   #15
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Becky,
Too late now, but you can remove the shelf/box from the end cap pretty easily, just a few rivets. Then you'd find a lot of room behind the end cap to feel around and help maneuver the wire.
Just a note about the antennae. My '72 Overlander, and most 70s Airstreams, have a TV outlet on the street side wall just forward of the fridge (or whatever cabinets are installed on that side). In that outlet, which includes a 12V source, there is an old-style balun splitter that feeds a coax that goes to the overhead box in the end cap. That was the original FM radio feed. So you're likely to find two coax behind that box--one directly from your whip antenna location, and one from the TV outlet.
BTW, if anyone finds an antenna similar to this one http://www.airforums.com/forums/show...15&postcount=1 I'd sure like to know.
Zep
Old 08-10-2009, 01:37 PM   #16
Iwannagocamping
Dakota's Dad's Avatar
Rineyville , Kentucky
Originally Posted by beckybillrae View Post
Okay, so it's not even 3 months since I put this new antenna on. It's already rusty! I bought it off of ebay last year (needed another part off of it), so it's too late to return it. Talked to the guy I bought it from & told him it was a piece of junk! He directed me to the manufacturer. Well, I'm not going through all that trouble for a $15 antenna. I guess I'll give one of the regular Airstream guys a call & order an original parts one for twice or three times the price, unless someone has a better suggestion!
antenna...
See our blog here on how two RV/AS rookies tackle a 1979 Sovereign resto!!
Just the photos.. (sometimes you don't need the blog, just a picture worth a thousand words..)
1979 Sovereign International
2004 Ford Expedition Eddie Bauer
2 Golden Retrievers
Air #36788
TAC#3179
WBCCI #1265
Dakota's Dad is offline   Reply With Quote
Old 08-10-2009, 01:40 PM   #17
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Radio Antenna Nightmare
Greetings Becky!
The genuine Airstream part may not be as expensive as you fear. Out Of Doors Mart has the antenna listed in their on-line catalog for $18.95.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 08-10-2009, 02:17 PM   #18
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
You might want to rub it down in 2 or 3 coats of Liquid Glass when you install it and change out the mounting screws to stainless....
Old 08-10-2009, 02:17 PM   #19
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Originally Posted by overlander64 View Post
Greetings Becky!
Kevin
That looks exactly like the antenna I put on. The manufacturer is online at www.metraonline.com They might have the whip antenna that Zep is looking for. I'm just wondering if Airstream itself carries an antenna that is manufacturered by someone other than Metra. I can't make out the name on the package of Out of Doors mart. I just don't want to go through the work of taking the old (not really old) one off & putting a new one on to have it rust in 3 months again!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-10-2009, 02:19 PM   #20
Becky B.'s Avatar
1964 17' Bambi II
I think I'll clean it up & try some Sharkhide (I have it) before I change it out. Good idea!
Becky
1964 Bambi II
1988 Avion 32S
Old 08-10-2009, 02:38 PM   #21
richinny's Avatar
2011 34' Classic
you could buy it and leave it outside for 3 months to see if it rusts
Ricky
Old 08-10-2009, 02:46 PM   #22
WBCCI 11067 WDCU
ckeysor's Avatar
1986 25' Sovereign
Atlanta , Georgia
Images: 30
Radio Shack does have the part
Becky,
I had the same problem with the antenna wire when I replaced mine. I found the part at Radio Shack. I will admit it took investigating several stores but found one finally. I think this is the part Solderless Motorola-Type Inline Jack - RadioShack.com
Even if this isn't the one, they do have it...I swear.
Good Luck
Chris
Chris Keysor
WBCCI 11067
1986 Sovereign 25' CB
2007 Chevy Silverado 1500
2007 Toyota Land Cruiser
ckeysor is offline   Reply With Quote
Old 08-10-2009, 03:02 PM   #23
Becky B.'s Avatar
1964 17' Bambi II
Originally Posted by ckeysor View Post
Becky,
Good Luck
Chris
It's the antenna itself that's rusting. Radio Shack was the first place I went locally to look for a new one (before I got my cheapie one off ebay)
Becky
1964 Bambi II
1988 Avion 32S
Old 08-10-2009, 05:26 PM   #24
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Zep
This is the closest I can find (Auto Zone):
Part number: AW-US13
Old 08-13-2009, 12:59 PM   #25
1976 24' Argosy 24
Milford , New Jersey
Becky,
Zep
Zep, check out my thread in the radio section of the forum. Ganglin found an almost exact replacement. If you can find the post let me know. George.
Gkiesel is offline   Reply With Quote
Old 08-13-2009, 01:36 PM   #26
1976 24' Argosy 24
Zep, here is a shortcut to the post. http://www.airforums.com/forums/f450...osy-53414.html
Radio Antenna sovereignrwe Audio, Video & TV 8 12-15-2008 02:21 PM
Radio Antenna rochar3 Exterior Restoration Forum 2 09-22-2008 09:53 AM
Radio Antenna for 1962 FC smcpheters 1960 - 1963 Flying Cloud 7 06-18-2008 07:40 AM
What kind of CB radio/antenna Stream 1529 Tow Vehicles 46 04-18-2008 03:38 PM
Radio Antenna niftypkg Phone, CB & Ham Radio 5 02-17-2007 03:20 PM
