Old 01-16-2011, 08:15 AM   #1
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Radio antenna needed?
Was wondering what the consensus is on whether I should keep a radio antenna. Mine looks to be in good shape but is the source of a small water leak when it rains.I'm thinking of just removing and patching the hole as I did with the TV antenna. The gasket is in seriously bad shape on this one and a new one will need to be made.
Will a portable radio work inside all that aluminum, with it's antenna?
SilverHoot is offline   Reply With Quote
Old 01-16-2011, 08:17 AM   #2
Yes, but not very well.
Old 01-16-2011, 09:02 AM   #3
Ottawa , ON
Why not just fix the leak around the antenna?
ďCourage is being scared to death, but saddling up anyway.Ē
Old 01-16-2011, 09:13 AM   #4
SilverHoot's Avatar
1967 24' Tradewind
Here's what I have
Aage,
Probably will go ahead and fix it. Any ideas on gasket material? Not sure what this old gasket was looks like a paper product.
Old 01-16-2011, 09:45 AM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Michael,
I have an AM/FM Kraco that was installed in my 68 at some point. It is old but works. We listen to it all the time and the antenna is a must. I have tried a portable inside. Local FM is fair to poor, distant FM and AM is no go. When inside the trailer you are basically in a large aluminum Faraday cage which blocks RF signals.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 01-16-2011, 09:56 AM   #6
SilverHoot's Avatar
1967 24' Tradewind
Bruce,
Thanks for the input and was what I figured to be the case. Need to figure out the gasket. I may make a plate about the size of the old gasket out of some heavy gauge aluminum with gasket/sealer between the plate and the skin and the plate and the antenna.
Old 01-16-2011, 10:01 AM   #7
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Faradays are illusive
Originally Posted by 68 TWind View Post
Michael,
I found this illustration of a Faraday cage. Unfortunately the door has been left ajar, and the Faraday has escaped.
Ken
Old 01-16-2011, 10:18 AM   #8
68 TWind's Avatar
1968 24' Tradewind
They are really hard to get back in the cage!!! Better watch out.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 01-16-2011, 10:24 AM   #9
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Buy gasket material at auto parts store. Bed with some vulcum or other non silicone caulk. As an aside, my radio is hooked up to the original roll-up antenna. Have picked up philadelphia stations as far as Virginia Beach and Bath, NY. Sal. And replace those bolts with stainless. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 01-16-2011, 10:31 AM   #10
SilverHoot's Avatar
1967 24' Tradewind
I actually think the gasket material will need to be fairly rigid and at least as large as what is left of the old one, so that the stresses are spread.
Old 01-16-2011, 11:11 AM   #11
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I put a 12v radio/cassette player from a truck that was updated to a CD player in my Safari. It was free so I gave it a go and it really works well. I too got rid of the antenna on my Safari and patched the hole. All I did was lay out an antenna wire inside the over head cabinet. That is also were the radio/cassette player is installed. I'm amazed at how well it works.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 01-16-2011, 11:14 AM   #12
Ottawa , ON
Hootie,
I was going to say just something simple like inner tube, but after seeing the size of your antenna's base, something thicker and fairly flexible might be in order. It appears to me that the base is sitting on a curved portion of the body, and therefore the gasket will need to fill a fair bit.
As Sal mentioned, a liberal dousing with Vulkem is also a necessity.
Old 01-16-2011, 11:51 AM   #13
SilverHoot's Avatar
1967 24' Tradewind
Going to patch
Just put a portable radio in it and checked reception, worked great! I'm going to go ahead and do as Tim did and put one out of sight in the endcap storage area above the dinette.
Old 01-16-2011, 02:05 PM   #14
r carl's Avatar
Lin , Ne
I would clean it up and put it back on with vulkem.
Clipper, Land Yacht, Radio TV Speakers masseyfarm Audio, Video & TV 2 06-23-2013 10:49 PM
Looked at airstreams today.. Advice needed. mikeandnora Buyer Guidelines 45 02-09-2011 11:27 PM
Frame Fabricator Needed in Alabama Benjo Repairing/Replacing Floor &/or Frame 14 01-30-2011 07:03 PM
Courtesy parking or rental parking needed, Perris Valley, California skydiva Our Community 1 01-13-2011 06:13 PM
Radio on house battery michalakes Electrical - Systems, Generators, Batteries & Solar 1 01-05-2011 02:07 AM
