Old 03-28-2010, 10:50 AM   #1
Wooden Rivet's Avatar
1956 26' Cruiser Overlander
McLeod , Texas
Radio antenna help please
I just installed JVC car radio/CD player under control panel in our '71 Tradewind LY.
Everything works except radio signal is basically not there. The original antennae wire is being used for the hook-up, but does not fit the hole on the radio itself. I started to solve that by looking for an adapter online. Quickly found out that they are listed by auto year and make, and since AS is not listed, was not able to order an adapter. In the meantime I have wrapped the male end of the AS antenna wire with aluminum foil trying to make contact and use the radio until I can find the correct adapter. Has not worked.
Help please.
Tom
Wooden Rivet is offline   Reply With Quote
Old 03-28-2010, 01:22 PM   #2
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Help please.
Tom
Hi Tom,
I can't tell from your description exactly what you are doing. however what I think you are doing is probably causing the antenna to be grounded to the chassis of the radio. That would definitely cause the radio signal to be very weak or not there at all. I would suggest buying a connector that fits the radio. Then cut off the old connector from the antenna cable and solder ( or however it is designed to be attached) it to the antenna cable.
If you posted some pictures of both connectors and what you are doing with the tin foil, that might help.
regards,
Ken
Old 03-28-2010, 06:53 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Yep. As they say, this thread is useless without pics.
If you post photos, we can probably identify the connectors and point you towards a source of adapters. The recent aftermarket car stereos all use the same cheesy connector so it's mainly a matter of figuring out what's on the airstream.
Soldering a coax splice is difficult even for the initiated so I don't know if I'd recommend that.
Old 03-28-2010, 09:00 PM   #4
1966 30' Sovereign
1963 22' Safari
orlando , Florida
Trying to rig up an adapter maybe an exercise in frustration. In the meantime,find a cheap portable ray-jo wit head phones. They never brake.
richie rich is offline   Reply With Quote
Old 03-28-2010, 09:18 PM   #5
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
The antennnea adapters are either large diameter of small. It sounds like the AS wire has the large male end & the radio has a small female end. I picked mine up at the local AutoZone store. Go there before you start cutting the wire. Look at parts 40-GM12 & 40-GM21.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
replacing radio antenna on 71 Lumatic Audio, Video & TV 17 07-06-2009 07:31 PM
Radio Antenna sovereignrwe Audio, Video & TV 8 12-15-2008 02:21 PM
Radio Antenna rochar3 Exterior Restoration Forum 2 09-22-2008 09:53 AM
Radio Antenna for 1962 FC smcpheters 1960 - 1963 Flying Cloud 7 06-18-2008 07:40 AM
Radio Antenna niftypkg Phone, CB & Ham Radio 5 02-17-2007 03:20 PM
