Old 12-18-2012, 05:24 PM   #1
rogerdodger's Avatar
Fresno/Clovis , California
Radio antenna connector too large!
I have an am/fm/cd radio by BMW left by a tenant, I installed it in my Argosy. CD player works, but antenna connection much smaller than the connector coming from the radio antenna on the side of the RV. I found a universal multi-connector at walmart, but the BMW radio didnt have a fitting that worked. Any ideas?
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 12-18-2012, 05:34 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I have had this situation in British cars... there is an adaptor you can get to go from one to the other. Not available at Radio Shack. Try a real car audio place.
Old 12-18-2012, 06:33 PM   #3
Ottawa , ON
Could you post a photo of the BMW connection please?
ďCourage is being scared to death, but saddling up anyway.Ē
Old 12-18-2012, 08:26 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
If itís a newer radio Iím guessing you have a FAKRA type RF antenna connector on the back of the unit. Rectangular housing, in beige or black for RF, with a small coax fitting inside?
Image Search Results for FAKRA rf connector
The Europeans have been using these for a decade or so.
The connectors are keyed and color coded for different applications. AM/FM, Sat, NAV, Phone, ECT.
Thinking off the top of my head again,
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 12-18-2012, 10:07 PM   #5
Ottawa , ON
Thanks, Tom.
Yes, I would say it's just another 75-ohm connector, made smaller. At first, I thought it might be one of the DIN connectors, since BMW is European, but then I realized that any electronics today is almost certainly made in the Orient, where smallest and cheapest is the rule.
Old 12-19-2012, 11:15 AM   #6
Picture-here it is!
Here is what I want to do: plug antenna into the radio. Thanks for all the help.
Roger
Air# 29488
Old 12-19-2012, 11:45 AM   #7
newsgauger's Avatar
1976 Argosy 28
Milton , Ontario
Hi Roger,
Tom Nugler hit the nail on the head with the connector needed.
If an audio place doesn't have what you need, I would suggest going to the auto wreckers, as they might have one.
Chris
newsgauger is offline   Reply With Quote
Old 12-19-2012, 11:46 AM   #8
Here is what I found, will this work??
Amazon.com: Scosche Vwa3Rb Audi, Bmw and Vw Reverse Antenna Kit: Car Electronics
Roger
Air# 29488
Old 12-19-2012, 01:31 PM   #9
Tom Nugler's Avatar
1972 25' Tradewind
Looks about right. Check the grooves on the housing to see if they match up. If you can't tell for sure and the keyways don't line up you may be able to trim the ridge off the radio connector. There is a locking tab so even if you have to do any trimming the plug shouldn't come off the radio.
Good Luck, Tom
AirForums # 2806
WBCCI / VAC # 6411
Old 12-19-2012, 08:09 PM   #10
Ok, I ordered it. Will let you know how it works out. Maybe others can benefit from our efforts. Thanks to all for the help.
Roger
Air# 29488
Old 12-24-2012, 03:46 PM   #11
I got it today, works great. Now I have FM radio and CD player. Next, some decent speakers. Any ideas?
Roger
Air# 29488
Old 12-24-2012, 03:49 PM   #12
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
A/D/S. Polk. Blaupunkt.
Old 12-24-2012, 04:46 PM   #13
Any online recommendations?
Roger
Air# 29488
