Old 07-07-2005, 08:37 AM   #1
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
Radio Antenna
On our last outage, we lost our radio antenna. Any suggestions on a replacement? Any time saving suggestions on the replacement work? How does one get to the back of the radio in the trailer if he wanted to run an a/b switch to different source to the speakers in the trailer?
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 07-07-2005, 09:55 AM   #2
Alden Miller's Avatar
1993 34' Excella
, Maryland
I just replaced the antenna on my excella this past weekend. We went to the auto parts store and picked a replacement antenna from the selection that they had. For mine all I had to do was unscrew the antenna from the base and screw the new antenna on. There were a couple of indexing nubs on the base that didn't quite match with the new antenna. I knocked these off with a die grinder.
Now, if you are talking about the antenna cable breaking between the exterior base and the radio I can't help.
-Alden
1993 34' Excella 1000
2005 Dodge Ram 3500 Diesel
(No it doesn't have a HEMI in it)
Alden Miller is offline   Reply With Quote
Old 07-17-2005, 09:06 PM   #3
1972 31' Sovereign
Oakdale , Minnesota
An update: I was able to obtain an antenna with the spring flexibility. I was not able to find this type of antenna at the two auto parts stores that I tried. I purchased the antenna at Fleet Farm.
I kept the original 1/3 ball base that screws to the trailer, and to the 2/3 ball connected to the new spring antenna. The teeth on the two pieces aren't perfect, but are 95%, and not noticeable except by a perfectionist.
Mark
Old 07-18-2005, 07:31 AM   #4
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Thumbs up CB 108" whip
I need to source an old style 108" CB whip antenna for my '65 Safari.
Anyone have any suggestions? Sure would like to replace as-original.
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 07-18-2005, 07:42 AM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Radio Antenna
Greetings driftwood!
Given their recent shifts in product line, I am not certain whether my source will still have them; but I was able to special-order a 108" CB whip antenna for my '64 Overlander from my local Radio Shack Franchisee. I mention the fact that he was a franchisee because I am not certain whether the antenna came from one of his "other" sources or Radio Shack as he operated an appliance and furniture store from the same location. It has been about four years since I purchased the replacement mast and spring base for my antenna.
Good luck with your search!
Kevin
Kevin D. Allen
AIR #827
Old 07-24-2005, 08:42 AM   #6
1972 27' Overlander
Concord , North Carolina
I may have a 108 antenna laying around from my trucking days. I don't have the spring know, but your welcome to the antenna if I can find it. Robert
solitairenc is offline   Reply With Quote
Old 09-03-2005, 10:33 AM   #7
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Images: 35
Rivet Radio Shack to the rescue !
Thanks all ... & appreciate the lead - Kevin
My local Radio Shack had everything in inventory.
The 102" S/S whip, the 6" spring and the swivel base mount.
I got it ALL !
NORM #3305
Old 09-03-2005, 04:49 PM   #8
flamingo-kid1's Avatar
1967 28' Ambassador
Rockford , Illinois
Send a message via ICQ to flamingo-kid1 Send a message via AIM to flamingo-kid1
radio parts
If you stop at a REAL truck stop.. a BIG one, you can find most all of the stuff you're talking about here!
I'm just a pink flamingo on the great lawn of life :-)
flamingo-kid1 is offline   Reply With Quote
Old 12-15-2008, 02:21 PM   #9
Vintage Trailer Supply
VintageRV's Avatar
1956 22' Caravanner
Montpelier , Vermont
102" Whip Antenna with Ball Mount & Spring
The 102" whip makes a really great amateur radio antenna so it is worth keeping. Also, it looks very vintage.
There are 3 components:
- The stainless 102" whip
- The stainless ball mount
- The stainless barrel-style spring
The whip is available from Radio Shack online and they ship to your local store. It's stainless steel and as good as any.
The ball mount and spring are available through them too, but they carry only cheap chrome plated versions, not the better stainless versions.
Look around online for stainless versions and you'll be much happier with the result over time. We hope to carry them in the future so check with us, but they are available elsewhere with careful searching.
Steve Hingtgen
WBCCI #1573
VintageRV is offline   Reply With Quote
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
amateur radio antenna for motorhome white1949 Our Community 0 01-01-2003 10:17 AM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 06:28 PM
Antenna Wiring niftypkg Electrical - Systems, Generators, Batteries & Solar 1 09-22-2002 01:04 PM
Which Antenna ?? Jim Clark Audio, Video & TV 1 07-21-2002 06:32 PM
