10-17-2019, 09:37 PM
2016 28' International
Trois-Rivieres
, Quebec
Preventing TV wall mount from extending while traveling
I don’t know if others have experienced this irritant, but our extendable bedroom TV wall mount would extend when traveling or when we bumped into it inadvertently.
The solution I found is a U shaped block that slips onto the mount arms and prevents them from separating (see picture). I cut the block out of a piece of hard plastic but I imagine that wood could also be used. So far it seems to do the job.
Any other solutions?
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap,
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
10-17-2019, 09:53 PM
2017 30' International
Broomfield
Sounds like the spring loaded lock is broken or stuck. It should “click” flat when the TV is pressed against the all. I’d check that out.... there is a strap below that disengages the locking mechanism....
I have the exactly the same mount and mine locks so it does not extend while in motion.
10-17-2019, 10:42 PM
2013 25' FB Flying Cloud
Longmont
Our 2013 25FB has just one TV, in the living area. It is also on an extendable mount.
It used to always stay latched, but a couple times lately the mount has extended a bit while we were underway. 38,000 miles on the trailer.
Your block looks like it will work. I think I might try a velcro strap first.
10-18-2019, 04:46 AM
2012 25' FB International
Trent Woods
, North Carolina
Yeah, I use a velcro strap on my bedroom TV, that has never latched.
Larry
10-18-2019, 08:12 AM
2019 30' Classic
Canfield
, Ohio
I found out that the TV brackets need a little silicone spray to keep them functioning properly. It also stops the squeaks and squawks that get pretty annoying. The lock works much better
Do not spray without setting something out to protect your bedding or seating under the TV or you'll be sleeping with the dog.
x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Our Google images and chat: https://photos.app.goo.gl/CMQbpNXQwapMnj8t9
10-18-2019, 08:57 AM
2017 27' Flying Cloud
Fort Worth
The problem I have is not with the arm extending but the HDMI cable coming out of the back of the television after travel.
10-18-2019, 11:50 AM
2018 25' International
Boise
, Idaho
Extendable TV
Our bedroom TV has the swing mount and I've never trusted it to lock. I use a velcro strap to wrap around it and the frame when traveling. Never have had a problem. I did the same thing with our awning..a grey piece of velcro keeps it from potentially coming out while traveling. Velcro is almost as handy as duct tape...
10-18-2019, 12:10 PM
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
I concur. You may have to oil the spring.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
https://www.facebook.com/groups/2284022111820203/
10-18-2019, 01:50 PM
Half a Rivet Short
Carlisle
, Pennsylvania
Hi
We've been over some pretty crazy roads. Neither of the TV's has "auto extended" while in transit. I agree that the latch on yours sounds like it is not functioning properly.
The magic block you show would be pretty easy to 3D print.
10-18-2019, 04:10 PM
Trois-Rivieres
, Quebec
Thanks Wulfraat, I checked the spring loaded pin and it does seem to operate normally when you pull the strap down, but it doesn't "click in" and hold the two wall mount arms together when you press the TV against the wall.
10-18-2019, 07:09 PM
2019 25' International
Tumwater
Have 2019 international and have had this problem. Spring locking mechanism would often get stuck in the lock position. Used a Velcro strap to clamp it down instead. Took the trailer in for some warranty work and they decided to replace the entire tv mount.
10-18-2019, 08:29 PM
2007 25' Safari FB SE
Carolina Low Country
, South Carolina
We have the straps and velcro solution. It works very well and we never have to worry about the TV
StreamNTyme
10-18-2019, 09:54 PM
2013 22' FB Sport
Cross Plains
, Wisconsin
I bought a trailer and the small sleeve that held the retractable bin was damaged and it would stay secure -- drilled out old sleeve and bought a new sleeve at hardware store -- glued in and it now holds securely. Sleeve was less that $2. If pin works, easy fix.
10-19-2019, 10:30 PM
2018 27' Flying Cloud
APPLE VALLEY
Good for you. Mine has always auto-extended from the first day of ownership. Dealer's help was to tell me push it in until it clicks. That, like much of the advice given, seems obvious but ineffective. I wouldn't ask for help if the normal operation worked.
10-20-2019, 07:28 AM
2017 16' Sport
Woodstock
, New York
Bill that’s one issue that needs some thought, believe me you do not want a broken HDMI connector, ask me how I know!
10-20-2019, 07:31 AM
2017 16' Sport
Woodstock
, New York
[QUOTE=StreamNTyme;2299660]We have the straps and velcro solution. It works very well and we never have to worry about
Velcro, Gorilla Tape, ZIP Ties are all my favorites
10-20-2019, 08:06 AM
Half a Rivet Short
Carlisle
, Pennsylvania
Hi
Indeed "back then" it should have been replaced while you were under warranty.
10-23-2019, 02:19 PM
Trois-Rivieres
, Quebec
This makes sense but in my case, and possibly others, the pin in the lower arm which is pushed up by its spring doesn't extend far enough into the sleeve. In addition, the head of the pin is rounded, so it doesn't take much lateral pressure for it to slide out of the sleeve and for the arms to extend; in which case, you don't need the strap to pull down the pin, just pull the TV towards you and the pin will be pushed down and slide out of the sleeve. If you keep an upwards pressure on the pin with your fingers to keep it in place, the arms will not separate.
So if you wrap the strap tightly around both arms to hold the pin in place and secure the strap with Velcro (or an elastic band), the arms will stay together and not extend.
10-24-2019, 07:18 AM
High Point
, North Carolina
Same issue. The lock works fine but bouncing that inevitably occurs on some of our rotten roads is enough to pop it out from the locking pin. I wrap the closed arms with a heavy twisty that's available from Home Depot. It does the job but getting it on securely is a bit of a pain. I love your block solution assuming it's tight enough that IT doesn't bounce off. Some of the roads we've been on in this country are in dire condition!
