Old 07-07-2010, 10:39 AM   #1
1990 34.5' Airstream 345
Lewiston , Maine
Question power question
I finally got my TV and DVD hooked up last night. I noticed that the brightness on the TV kept changing. Is this an indication of power fluctuations? I am hooked up to 30amp service in a campground.
Thanks!
gowiththeflo is offline   Reply With Quote
Old 07-07-2010, 11:57 AM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
IS your AC runner? the compressor on that turns on and off and could account for it. Other than that is might be a power flux with all the other RV's hooked up.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-07-2010, 05:04 PM   #3
richinny's Avatar
2011 34' Classic
does the tv self adjust based on the room lighting? a volt meter would tell you if it is voltage fluctuations.
Ricky
Old 07-07-2010, 06:07 PM   #4
Lewiston , Maine
anything to regulate power
Thanks...
Is there anything I can get to regulate the power inside or at least to certain outlets where sensitive equipment is plugged in? Would a UPS work?
Old 07-07-2010, 06:37 PM   #5
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
ups=more batteries
that's all it is. check this out:
Surge Guard RV Voltage Regulators - Product - Camping World
this or something like it will help out. notice the cost.
If you have a 12v powered television (TV on this forum usually means tow vehicle) the power is filtered over the coach batteries and that will keep the voltage constant. or, you can use an adequately sized inverter generator that provides ripple/surege/sag free AC.
$ will solve any problem.
be cool
ol' bill
wmarsha is offline   Reply With Quote
Power question tripod58 Electrical - Systems, Generators, Batteries & Solar 14 10-30-2009 06:18 PM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 08:07 AM
Fridge Power question Gastrolith Electrical - Systems, Generators, Batteries & Solar 4 07-19-2009 11:08 AM
Question on power jack Alex Electrical - Systems, Generators, Batteries & Solar 7 12-01-2003 11:18 AM
Power Jack Question 68 Suburban Jacks, Stabilizers, Lifting and Leveling 3 10-11-2002 06:05 PM
