Yep, what he said. The factory does not set these and they are normally turned off. Getting the plastic door off is a bit difficult. Prey with a screwdriver. Don't worry if it gets damaged, you probably won't put it back on.
Check that each wire running to the sub actually works by disconnecting one at a time. Red and white wires with the large connectors. My right signal did not work due to a break in the wire in the wall. It was fixed under warranty.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
