Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 06-25-2008, 09:14 AM   #1
Rodger with a D
Profile:  1970 27' Overlander
Colo Spgs , Colorado
out with the old & In With The New (1970 Overlander )
Hola Class
When we got the trailer if had an blank spot where the original AM/FM/8 Track had been. The raido antenna was broken at the point tip where it is fastened to the cable and the outside part was rotated downward that swung with trailer movement. The original speakers were still behind the face covers, but with no wires.
I now have a new side mounting antenna from Radio Shack to install. The ( working ) speaker's with a looong section of wirng harness came from the local pick & pull for the sum of $4 . The radio is an car unit that set me back $10 from the same place.
I was given an ( working ) vintage 23 ch Model T-28 Royce Table CB to put in the same space.
Now from reading what others have done, I want to jump in with both feet and copy you by doing what I wanted in the first place and switch to an AM/FM/8 Track or Cassette.
Will it ever stop.
Rodger & Gabby
COS
Rodger with a D is offline   Reply With Quote
Lock for 1970 Overlander Kiah 1970 Overlander 4 08-01-2008 01:18 AM
1970 27' Overlander jaybay6347 Member Introductions 2 08-23-2007 07:55 AM
1970 Overlander Fridge damkdeck Refrigerators 6 02-26-2007 04:20 PM
Adding an awning to 1970 Overlander TroutStream Awnings 3 06-13-2004 07:34 PM
Brakes on 1970 Overlander TroutStream Brakes & Brake Controllers 7 05-23-2004 12:52 AM
