Old 02-12-2010, 08:58 AM   #1
blickcd's Avatar
Milford , Ohio
Old skyliner TV antenna and roof vent question
My trailer is a 1979 31' center bath. When the TV antenna is lowered the rear end of it is right above the center roof vent. The back end of the antenna has a downward curved loop that nearly rests right on top of the vent lid. No problem as it is an original aluminum lid and won't be damaged.
Now I am thinking of replacing that old style light/vent combo unit with a modern translucent roof vent, with a new light fixture off to one side. Note I already installed a Fantastic Vent in my living room so no need for another one of those. My concern is the lowered TV antenna cracking or damaging a new plastic vent lid.
I've thought about inverting the loop on the antenna to give some extra clearance, as I assume that won't affect TV reception. I've also thought about raising or modifying the cradle that the antenna lowers onto, again for a few inches of extra space.
I know it will be impossible to have a new vent opened all the way and the antenna lowered, and I'll have to pay attention when operating either one. That aside I was wondering if anyone has changed out their center vent when they had such a conflict with the TV antenna, and how they resolved it.
Christopher
blickcd is offline   Reply With Quote
Old 02-12-2010, 09:03 AM   #2
Christopher
Raise the cradle, but no more than necessary, as the antenna is subjected to the wind passing over the trailer when in motion.
Old 02-12-2010, 10:44 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Skyliner Manual
Do you have the original cradle? Here is the antenna manual - drawing shown on Page 8.
Old 02-12-2010, 01:15 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
When I replaced my antenna with a batwing I installed it so it lowers about 5 degtrees off the center line and mostly clears the roof vent. No problem with getting blown around on the road.
Old 02-12-2010, 02:05 PM   #5
blickcd's Avatar
Milford , Ohio
Yeah, the cradle is original. To raise it I would most likely cut the vertical legs about halfway up, then with a pieces of flat aluminum stock and pop rivets I would splice it back together with a 1" (or whatever was needed) gap between the cut I made. Maybe have a 2" overlap of new aluminum/original cradle leg.
I have considered that when the time came to install a new antenna I would have the base rotated slightly as suggested. However, the old antenna still works great after I replaced the broken gears and wired it with new coax.
Christopher
Braund Skyliner antenna amplifier needed. bmklawt Audio, Video & TV 21 02-16-2009 07:29 AM
Roof antenna on '77 LI Pets Audio, Video & TV 7 09-20-2006 10:08 AM
TV Antenna on Classic Roof Chuckles General Motorhome Topics 20 08-16-2006 06:54 PM
Hehr roof vent question pgajkowski Roof Vents, Skylights & Fans 1 06-06-2005 08:25 AM
