Old 02-06-2014, 08:04 AM   #1
Rockville Centre , New York
No TV reception with Winegard antenna
Don't get any channels when those around us all have reception. Have two year old HDTV and a one year old power booster. Not sure how I can trouble shoot this beyond checking the connections.
JMBORST is offline   Reply With Quote
Old 02-06-2014, 08:14 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
The power booster provides DC power to the antenna. The actual amplifier is in the antenna head.
You can get up on the roof and check for DC power on the connection to the antenna itself with a meter. There should be 12v. Winegard includes troubleshooting information in their installation and operation guide, available here:
http://www.winegard.com/kbase/upload/2452013.pdf
Old 02-06-2014, 08:16 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I have the same problem.
Hope someone responds with a way to check the amplifer without having a specialty meter!
Alan
Old 05-19-2014, 08:31 PM   #4
1999 35' XL 355 w/slide
Arlington , Tennessee
Try the Jack antenna replacement for the Winegard antenna head. It is less directional and comes with an amplifier that can be added if needed.
tebreuer is offline   Reply With Quote
Old 05-19-2014, 09:30 PM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
What did you mean by a one year old power booster? The winegard antenna has an amplifier built in. If you put another booster in line, the amplifier in the antenna is not getting any power and will not pass much signal. The winegard antenna amplifier power supply is, at least in my trailer, in the wall box near the living area TV. There is a switch on it, and an LED that indicates that power is applied. The wiring in my trailer had been modified such that the cable input had been converted to another output to drive an outside television. It took a while studying the manual to sort it all out.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-25-2014, 05:44 AM   #6
2012 25' FB Flying Cloud
Grand Rapids , Michigan
I am famous for forgetting to push the little power button to the antenna,although I always seem to remember to shut it off. Do you have a green power light?
Jwestman is offline   Reply With Quote
Old 05-25-2014, 06:44 AM   #7
pappy19's Avatar
Garden Valley , Idaho
If you are using the satellite then you don't use the power booster. The power booster is only for using the antenna for local reception. I have the automatic Wineguard and once I am plugged into the electric power source, I flip the dish to on and by the time I get other things settled, the dish has found the right setting. I don't remember when I used the power booster last, maybe 4 years ago.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Winegard HA-0130 antenna... might buy Lothlorian Audio, Video & TV 3 03-10-2014 09:56 PM
Jack Digital Over-the-Air Antenna Tallytown Audio, Video & TV 21 02-17-2013 11:19 AM
Alternative TV antenna or bypass WineStream Audio, Video & TV 10 04-02-2012 06:48 AM
New Satellite Antenna on Roof B&J Audio, Video & TV 13 03-04-2012 09:41 AM
Help with antenna location and setup dznf0g Phone, CB & Ham Radio 0 10-16-2011 08:46 PM
