Old 05-20-2018, 08:21 AM   #1
2017 25' Flying Cloud
Rock Island , Illinois
No Power to Antenna When Using Inverter
When testing the inverter on our 2017 Flying Cloud 25FB, we tried the TV in the salon and could not get any channels (had plenty of channels on shore power). Apparently, the antenna did not power up. Does the antenna booster not work with the inverter? Any recommendations?
Thanks!!
Sammy99 is offline   Reply With Quote
Old 05-20-2018, 08:44 AM   #2
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
The antenna booster works on 12 volt. Was the green light on?
Ray B.
Adventure.AS is offline   Reply With Quote
Old 05-20-2018, 10:14 AM   #3
DKB_SATX's Avatar
Alamo Heights , Texas
I'd point out that the inverter (as wired by Airstream) is *ALWAYS* available, even when the store/use relay is in the Store position. So you might have gone to the trailer to test, fired up the inverter, the TVs worked but the amp wasn't getting any battery power. When you plug into shore power, the converter provides 12v to the trailer regardless of the store/use setting, I think.
— David
DKB_SATX is online now   Reply With Quote
Using inverter and generator together? awiegel Electrical - Systems, Generators, Batteries & Solar 38 10-07-2020 12:09 PM
Best way to wire inverter/converter/shore power for seamless AC power justgoclimb Batteries, Univolts, Converters & Inverters 39 06-28-2017 04:51 PM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Is it bad to remove the antenna up top if I don't plan on using it? Biggysmalls Audio, Video & TV 22 10-04-2010 09:37 AM
