Originally Posted by Budget M3
Have not seen that, but I think most of us that use televisions in our AS probably use a 110v set and run an inverter from the 12v source when not plugged in to shore or generator power.
This is a true statement, but I bought one of the Vizio TV's that Darkspeed is referring to and it has worked out very well. I just installed a 12v outlet close to the TV and power it directly from there. Not needing an inverter means not having to find it, connect it up, listen to the cooling fan and no heat and battery consumption from the heat produced by the inverter.
Like Darkspeed, I just stumbled across this TV at Sams. When this TV needs replacement I will search for a 12v powered TV, so I don't need an inverter.
Dan
