Old 12-09-2012, 11:02 AM   #1
Machinist
Blondin's Avatar
1971 31' Sovereign
Yakima , Washington
Newbie AS question..... TV antenna?
I am a new airstream owner and new to the forum. I have been thinking about tossing the tv antenna.
Are there any unwritten rules about AS and keeping them as original as possible???
The tv antenna seems somewhat obsolete and thought I would ask.
Mark
Blondin is offline   Reply With Quote
Old 12-09-2012, 11:06 AM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Why does the TV antenna seem obsolete? They work great for the currently in use digital signals.
Vaughan
Old 12-09-2012, 11:12 AM   #3
Machinist
Blondin's Avatar
1971 31' Sovereign
Yakima , Washington
That is true I guess. I am not up on the newer digital system. They must still work then.
Old 12-09-2012, 12:03 PM   #4
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Older TV's need a converter box in the line from the antenna to the TV. Newer units work well with the digital signals. Our 19 inch $89 Walmart off brand LCD monitor/TV works just fine.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 12-09-2012, 12:21 PM   #5
1974 Argosy 20
Kooskia , Idaho
As for unwritten rules about keeping things original, I would only say that if you have a virtually untouched very very original AS and a somewhat rare floor plan or model would you be best to keep it original. Otherwise, update, and make it to your liking.
My 71 Caravel is so original that I don't modify it. My '74 Argosy is so far from original now that I have no problems making it newer, better, and to fit me just how I like it.
Old 12-09-2012, 02:16 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yep.....
Our new trailer Samsung get's better broadcast HD thru the antenna, than the flat panel LCD in the house duz thru cable.
Old 12-09-2012, 02:35 PM   #7
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
We have a 19" VIZIO in our '65 Caravel. Hooked up to the original folding TV antenna, the over the air digital signal comes through strong in areas that provide it.
Digital is different from the old analog signal in that you either have it or you don't. There is no fuzzy when you are almost there like analog.
Try your old antenna with a digital flat screen TV.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 12-09-2012, 03:03 PM   #8
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Aren't you limited to what ever channels are local to where you are at, using the old antenna?
goshawks00 is offline   Reply With Quote
Old 12-09-2012, 03:47 PM   #9
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Hi,
Antenna's do age, oxidize is a better word for it. Replacing the head with a new unit will benafit your reception and give you a stronger signal.
New systems also have a boster on them. It's a wall mounted afair with a 12 volt plug and on off switch.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 12-09-2012, 04:16 PM   #10
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Yes, you are limited to local broadcast, but sometimes that's the only way to get local news, weather etc.
We have been able to watch NASCAR, Olympic games, and other good stuff in High Definition over the air using the old antenna and our digital flat screen on the road. Sometimes, but not too often, local RV parks have HD on their cable.
Old 12-09-2012, 06:10 PM   #11
1983 34' Excella
1967 24' Tradewind
Images: 32
Originally Posted by Bigventure View Post
Hi,
I doubt that very much. Both mine work great, and the new one is 29 years old.
That much is true, but again, both mine had boosters when I got them. I did upgraded them to newer boosters, though.
Now, about that keeping things original vs. modifying it. I fall into the make it your own group. If I had enough money, mine would look like the interior of a private jet. It would still have the original antenna, though.
Vaughan
Old 12-09-2012, 06:54 PM   #12
Thumbs up Original or not....
There are no rules written or un-written about what you do to your Airstream.
That said, there are things that deserve to be kept as built though.
Sweet Streams...
Old 12-10-2012, 07:22 PM   #13
Machinist
Blondin's Avatar
1971 31' Sovereign
Yakima , Washington
Thanks for the advice!!
I think I'll keep it complete!
Mark
Old 12-10-2012, 08:49 PM   #14
mefly2's Avatar
2015 25' FB Eddie Bauer
Hi,
So, oxidation affects the RF signal induced in the antenna?
The signal booster likely has the most effect ...
Newbie Question Kd9 2011 - 2015 International 57 09-14-2015 07:08 PM
Newbie dumb question re sewer hookups Rich of SCal Waste Systems, Tanks & Totes 62 02-23-2012 07:12 AM
Newbie with question Reesestream 1969 Overlander 1 01-21-2012 11:00 PM
Newbie 190 question jamana1 Classic Motorhomes 4 11-12-2011 06:50 AM
'nuther newbie AS question re: RV parks.. Gringo On The Road... 18 05-26-2011 07:47 PM
