Old 05-06-2010, 07:57 PM   #1
2000 31' Excella
Maryville , Tennessee
Need new antenna.
Just got a new TV for my camper and need to get an "outside" antenna.
Please direct me where I can buy one that I can put outside maybe on top of camper while camping or somewhere.
Also, what happens with the old "crank up type" antenna on top of my camper with the knob inside on the ceiling and can it be used for anything ?
Will it be as simple as antenna to cable then cable to tv ?
Thanks........
Robbie R. is offline   Reply With Quote
Old 05-06-2010, 08:13 PM   #2
_
r u SURE there isn't already one of these up on the roof?
every a/s built in the last 30+ years has one (or the older style) antenna, that is....
http://www.winegard.com/kbase/upload/2452013.pdf
Upgrade your Sensar Antenna with Wingman for Optimum DTV Performance - Winegard
typically ALL 'streams also have a some signal 'booster' mounted in the wall near the coaxial connector AND 12v outlet.
cheers
2air'
Old 05-06-2010, 08:26 PM   #3
2000 31' Excella
There is one of those but I was not sure if it was for HDTV digital cable or the old signals.
If it will work for the new digital signals then I will just use it.
Thanks.
Old 05-06-2010, 08:29 PM   #4
_
yes it works with digitally transmitted signals...
however they DO sell a small gadget to "upgrade" the reception...
the "wingman" clip on linked in the 2nd link supposedly pulls in a few more stations in the uhf channel zone...
i've had NO problems using the standard batwing.
HD is dependent on the broadcast and tv capability , not the batwing.
cheers
2air'
Old 05-07-2010, 08:01 AM   #5
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Thanks.
Ours works just fine. Tried the "Wingman" but it doesn't seem to improve anything.
Ahab is offline   Reply With Quote
Old 05-07-2010, 08:06 AM   #6
2000 31' Excella
Thanks everyone. Do I need a box or anything in between the TV and the antenna or just plug it in ?
Old 05-07-2010, 08:28 AM   #7
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I assume that you have the round coax connector from the wall to connect to your TV in an Airstream that new. Just connect it to your new TV and you are good to go. The antenna does not care whether it is getting digital or analog, it collects it and passes it on just fine.
Vaughan
Old 05-07-2010, 09:52 AM   #8
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Depending on how old the TV is (more than a few years old), it may require a digital converter box. If it was mine and was old enough to require a digital converter box, I would replace it with a new one.
Regards,
Ken
What is it: Antenna and? bmklawt Audio, Video & TV 3 12-18-2008 11:32 PM
FM antenna Phil Gobie Electrical - Systems, Generators, Batteries & Solar 6 12-24-2006 11:28 AM
Which TV antenna? Ohanastar Audio, Video & TV 2 09-05-2005 12:58 PM
Antenna silverlassie Audio, Video & TV 19 05-01-2004 01:02 PM
TV antenna davidz71 Audio, Video & TV 14 03-14-2003 08:14 PM
