Old 11-10-2019, 07:55 AM   #1
2019 27' Flying Cloud
Lakeway , Texas
Need Help: How to remove automotive type stereo head.
I have a 2009 FC 23CB with the original Sony Automotive Type Stereo. I cannot get it to power up, hoping that it is just a fuse in the rear of the unit. However the special tool required to remove the head is nowhere to be found. Does anyone know if an easy way to remove the entire unit? Can the wooden facia it is mounted in be removed? There is a hand hole inside the upper cabinet but it is a rats nest of wiring and no one could possibly get their hand in there even if you could see where the fuse is. Any recommendations would be welcomed as we all know how expensive the labor charges are at the RV dealers.
lsawye01 is offline   Reply With Quote
Old 11-10-2019, 08:45 AM   #2
mpsgolf's Avatar
2015 28' International
Ofallon , Missouri
I recently had the same problem. There are typically two slots on the sides of the unit - you slide the tool into the slots to release the catches. I had to remove my plastic face plate first.
I happened to have some semi-flat metal bbq skewers. They slipped into the slot nicely and released the catches. Anything flat and about 1/4 to 3/8 wide should do the trick. If I recall I had to go about 2 inches into the slot to get to the catches.
mpsgolf is offline   Reply With Quote
Old 11-10-2019, 09:21 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
https://www.amazon.com/Radio-Removal...%2C145&sr=8-14
lsbrodsky is offline   Reply With Quote
Old 11-10-2019, 10:39 AM   #4
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I've pushed two dull round end butter knives into the slots to release the latches. When I hear the latch snap open, the radio will pull straight out.
I've also done it with flat blade screwdrivers, the long skinny one an electrician uses. (what tool you will need depends on how the slot is made)
Alan
Old 11-10-2019, 02:19 PM   #5
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
If you need the disconnect tools pretty sure I’ve seen them at Walmart in car stereo display.
GCinSC2 is offline   Reply With Quote
Old 11-11-2019, 10:31 AM   #6
BoatnutG2
BoatNutG2's Avatar
2015 28' Flying Cloud
2023 23' Flying Cloud
2013 Interstate Coach
Huntington Beach , California
I've used 8 inch zip ties.
BoatNutG2 is offline   Reply With Quote
Old 11-11-2019, 10:54 AM   #7
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Used a table knife - easy ....
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 11-13-2019, 10:51 AM   #8
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
A little bit late but if you want a visual of the clips look at about 8:40 of this video
https://youtu.be/b7gjvYc3fRU
Our Website: https://airstreamnerds.com/
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Want To Replace Stereo Head Unit DEITZ645 Audio, Video & TV 1 03-07-2009 06:31 PM
Automotive News... BillTex Tow Vehicles 6 12-27-2008 01:13 PM
Petersen Automotive Museum exhibit- In Los Angelas 1953 Flying Airstream "In the News" 13 07-19-2008 02:57 PM
Automotive paints; advice please SmokelessJoe Clearcoat, Exterior Paint & Trim 5 03-18-2007 02:16 PM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
