Old 11-22-2013, 04:36 PM   #43
lylesgl's Avatar
2007 27' Safari FB SE
Springfield , Virginia
Go to the electronic store of your choice and listed to the Bose Soundlink mini Bluetooth speaker. It sounds incredible for its size. In addition to running off 120v ac it has an internal battery that can be used when not connected to 120v
lylesgl is offline   Reply With Quote
Old 11-22-2013, 08:48 PM   #44
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
Originally Posted by Protagonist View Post
Easy way, cut off the existing connector, and splice on the connector you need. On the antenna lead, not on the Tivoli!
I was thinking that would work. I think I'll try it! Thanks!
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 11-25-2013, 08:53 PM   #45
1963 19' Globetrotter
Moline , Illinois
Problem solved
Forgot I posted this ,ended up putting in a Sony satellite ready car stereo along with some small hanging boat speakers from West Marine. Used the wiring that was installed at the factory for a CB that was never put in , along with the original whip antenna hooked to some new coax. Worked out very well.
63air is offline   Reply With Quote
Old 11-26-2013, 06:25 AM   #46
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Bose also has one for the IPOD that works on AC and battery. It does not require bluetooth . We have had it now for two years and love.
urnmor is offline   Reply With Quote
electrical system 67 tradewind boardsander Electrical - Systems, Generators, Batteries & Solar 3 10-14-2002 04:32 PM
Flowmaster RV exhaust system rdm Airstream Motorhome Forums 2 07-09-2002 03:35 PM
Charging System drmmlien Electrical - Systems, Generators, Batteries & Solar 3 05-09-2002 01:53 PM
The forums private message system PeterH-Airstreamer Forum Admin, News and Member Account Info 0 04-10-2002 12:25 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
