Old 12-28-2010, 03:24 PM   #15
bernermom's Avatar
2008 25' Safari SS SE
Southern , New Jersey
Thanks Ken I will call Sansung. I did try the input select button, and nothing happened.
It is proving to be hard to find a TV that will fit anyway. The mounting bracket is 200mm X 100mm and all the 22-23" TV's that I am finding are 100mm x 100mm VESA mountings.
bernermom is offline   Reply With Quote
Old 12-28-2010, 03:54 PM   #16
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
LCD TV's have a light bulb inside to illuminate the screen. I think it's a fluorescent bulb, but some have gone to LED's. That bulb eventually burns out and has to be replaced. It could be as simple as that.
Gene
Old 12-29-2010, 04:15 PM   #17
2005 19' Safari
GLENDALE , AZ
If the temperature inside your Airstream is really cold, the TV may not function because of the cold weather. (Ever noticed how fluorescent lights sometimes have difficulty starting in the cold?) You might try taking your TV inside to warm up to normal room temperatures, and then try powering it on again. Also, check your owners manual. Some models say normal operating temperature is 41-95 degrees F. However, this may not apply to your model.
Old 03-09-2011, 09:11 AM   #18
bernermom's Avatar
Finally got this resolved. Thanks Ken for the suggestion to call Samsung.
They told us that the problem sounded like the 'capaciter', and if we shipped it to their service center, they would replace that for free if it was the problem. If it was not the problem we would be charged a $80 for a diagnostic fee, or $120 if we also wanted it sent back to us. Or they would fix it for a charge depending on the problem. So we paid $56.00 to ship it back and gambled the additional $80 if it was not the problem.
While I never gamble, this one turned out to be a good bet. We received it back in less than two weeks and only spent $56.00. I guess they have had issues with that part since they replaced it even though the TV was out of warranty.
Diane
Old 03-09-2011, 10:35 AM   #19
Master of Universe
Gene's Avatar
Diane,
Thanks for the information. We have a smaller OEM Samsung in our 25'. Some people got Sony's in 2008 and some got Samsungs. Sounds like vibration was not the problem, but a bunch of bad capacitors.
Gene
Old 11-07-2011, 07:12 AM   #20
1983 31' Excella
2005 30' Classic
1993 33' Land Yacht
Wellfleet , Massachusetts
Can someone tell me where to purchase a wall mount for an Air Stream to mount a 15 inch TV on for the bedroom in a Air Stream Classic ?
I have found some on the internet but I want to get the right one and don't know what one to purchase .
Don
Don.44 is offline   Reply With Quote
Old 11-07-2011, 08:08 AM   #21
Master of Universe
Gene's Avatar
I think the best approach is to decide on a TV and find out what wall mount it will take—there are different size bolts and different patterns for them. This is mostly standardized though the information can be hard to find. We bought a Samsung last winter for the house and it had a couple of different bolt patterns. Then we bought a wall mount on the internet. One of the two came with the right sized bolts. Bolts are easy to buy at a hardware store. A call to the TV manufacturer may help and they may be able to recommend some wall mounts.
Gene
Old 03-10-2012, 08:29 AM   #22
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
VESA standard and mounts
Greetings
Although this thread is older, I will reply on what I have learned about TV wall mounting. I am still looking up info on the structural integrity of the AS walls. My unit came with a 19" 2010 HD unit that apparently was replaced by the original owner. I see holes where it looks like there was a mount in the bedroom and a hook still there. I just purchased a 24" Insignia LED 1080p that runs on 33 watts for $177. The best part about it was that CU rates it as the #1 on smaller TVs!
Mounting: VESA standard mountings usually have three sizes of square mounting configurations on electronics. For example, the 24" TV I bought uses the VESA 100x100 size. Most VESA mounts allow for more than one VESA size pattern. It is listed on the boxes along with the specs. of both mount and electronic device. The 19" weighs 7 lbs. The 24" weighs 10 lbs.
Airstream walls: The TVs weigh 7 and 10 lbs so they are not heavy items; however, it is important to consider travel stress. My thought is to provide a plate for mounting on the other side of the wall or remove the TVs when traveling. How can they be quickly mounted and unmounted? Is it enough to do what Airstream does, mount the TV and velcro it in place for travel? Has anyone ever torn their wall out with 7-10 lb TVs? Those of you with AS mounted TVs, is there any kind of bracing inside the cabinets they are mounted to or is it just screwed to the wall?
Old 03-10-2012, 12:27 PM   #23
Master of Universe
Gene's Avatar
Ours is bolted to the partition with the fridge on the other side. It locks down for travel. It is a bit tricky to unlock, but it can be done with some effort and fingers that bend backwards. I am unaware of any extra plate to spread the stress.
We are thinking of putting a small one in the bedroom. The only place to mount a bracket is on the partition with the shower on the other side. I don't want to drill into the shower. Has anyone done this installation?
Gene
Need advice on "Brand of adjustable water pressure regulator" to purchase. bambid Plumbing - Systems & Fixtures 3 07-03-2010 09:34 PM
Flatscreen TV Skycop Audio, Video & TV 10 09-05-2009 06:35 AM
A little advice-57 Overlander and propane "system"... SUEHOWIE LP Gas, Piping, Tanks & Regulators 6 11-08-2008 09:44 PM
Any "last minute" advice on the big trip? Wolf On The Road... 10 07-28-2004 01:46 AM
Hoping to buy my first "baby" this month! need advice!!! virgin Our Community 3 07-22-2003 09:30 PM
