Old 01-16-2006, 09:29 AM   #1
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
Need a better FM antenna
I want to upgrade our (OEM) roof mounted FM (and AM) antenna. I can walk 10 feet over to my truck and receive several FM stations that I can't receive in the trailer. Does anyone know of an upgrade that is a direct replacement for the factory antenna? I wonder if my truck's antenna will work?
Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 01-16-2006, 09:54 AM   #2
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Have you considered an in-line signal amplifier?
http://tinyurl.com/9gho9
The one on my Bambi looks like an ordinary short auto rubber FM antenna. It may just screw off like any car antenna. If so, be aware of the height of your replacement mast.
SilverRanger is offline   Reply With Quote
Old 01-16-2006, 10:11 AM   #3
DayStreamer
grizzy's Avatar
2001 19' Bambi
Mesa , Arizona
If you want a very good one you might try the Terk antenna ( http://www.smarthome.com/7744f.html ). I've never tried one on an AS but do have one at our home in the mountains - its the only way we could get any FM stations.
Dave
DayStreamer
2001 19' Bambi
02 Avalanche
Mesa Arizona
AIR #5591
grizzy is offline   Reply With Quote
Old 01-16-2006, 11:06 AM   #4
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
We have exactly the same problem on our 19' CCD. Even when we are in range of stations I normally get in the van, they don't come in on the coach radio. Or reception is crappy.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 01-16-2006, 11:47 AM   #5
geosouth's Avatar
2001 19' Bambi
Running Springs , California
Cool
I've struggled with the same thing on my new to me 2001 Bambi. I will leave the factory antennae alone and use an xm satellite antannae that I can mount when I set up. I was thinking of a permanent install for the sat antennae, but I like to be able to put the receiver in a radio outside on a table, too. This way I have two options when set up plus I put the receiver in my TV while driving. Satellite radio really works for me because I can pick the exact content I want to listen to and I hate commercials.
geosouth is offline   Reply With Quote
Old 01-16-2006, 12:18 PM   #6
Airstream25's Avatar
1995 25' Excella
1982 34' Limited
Albuquerque , New Mexico
Images: 21
Send a message via Skype™ to Airstream25
Upgrade (OEM) roof mounted FM antenna
Originally Posted by silverback
I want to upgrade our (OEM) roof mounted FM (and AM) antenna. I can walk 10 feet over to my truck and receive several FM stations that I can't receive in the trailer. Does anyone know of an upgrade that is a direct replacement for the factory antenna? I wonder if my truck's antenna will work?Thanks,
Ken
Why not just put a splitter (available from Radio Shack) on your TV antenna and connect that to your FM. Should work. I think FM frequencies fall between TV channels 6 and 7 so any antenna that receives broadcast TV should also receive broadcast FM.
Airstream25
KE5CKG on 2 meters
AIR #10274
Airstream25 is offline   Reply With Quote
Old 01-16-2006, 02:40 PM   #7
DayStreamer
grizzy's Avatar
2001 19' Bambi
Mesa , Arizona
Now that's a good idea - someones using their head! Simple and should be effective
Dave
DayStreamer
2001 19' Bambi
02 Avalanche
Mesa Arizona
AIR #5591
Old 01-16-2006, 05:17 PM   #8
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Sure is a no-brainer, but concealing the cable from the television to the FM radio may be problematic.
Old 01-16-2006, 06:05 PM   #9
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
And there's no free lunch. A splitter has loss and the signal to the TV will be reduced.
Maurice
Old 01-16-2006, 06:20 PM   #10
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
I recall that back in the 1960’s when FM was really starting to takeover or push-out popular AM radio stations that there was a way to made your own FM antenna out of TV cable. Not coax cable but that flat two wire kind that went to the TV antenna. The improvised FM antenna is shaped like a “T” with each end of the top part having it’s two conductors connected together.
I think the important dimension is the length of the horizontal part of the “T.” Since FM broadcasts between TV channels 6 and 7 the length of the “T” must be the reciprocal of that frequency band to match the desired FM wavelengths in inches. Perhaps someone has the necessary dimensions and can share them.
JStanley is offline   Reply With Quote
Old 04-02-2006, 07:38 AM   #11
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
L(feet)=468/Frequency For a half wave dipole.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 11:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 04:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 02:30 PM
Which Antenna ?? Jim Clark Audio, Video & TV 1 07-21-2002 07:32 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 12:34 PM
