Old 07-13-2005, 11:24 PM   #1
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Mystery wires behind stereo
Hi all, I pulled my my radio enclosure on my 04 Bambi, with Sony head unit but without A/V package, and behind it I found three different RCA wire combos coming from the frame with all of the other power and speaker wires. I have two Left/Right Wires, and one Left/Right/Video.
Where do they terminate in the trailer? I pulled off the two cable outlet plug at the rear bed and dug around in the wall, but no cables spotted.
I have attached a picture of the cables.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 07-14-2005, 06:41 AM   #2
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
Westfalia,
They are the pre-wireing for the A/V upgrade. Audio, video, and sub wires. If you unscrew the platform the bed is on, (screws inside the coach under the matress and under the platform accessable thru the rear trunk) you will find where some of the RCA cables terminate. This is also the compartment that the water heater is in.
If you look in the RS compartment under the dinette, between your water pump and freash water, I believe the sub woofer cables are there....
This is how it was on my '05 CCD...
Rgds
Kevin
Bambi_Bandit is offline   Reply With Quote
Old 07-14-2005, 07:28 AM   #3
Westfalia's Avatar
Images: 35
Thanks for the input! I'll pull the base for the bed today and see what I find. I know that the wires for the sub are not in the water tank area as I was doing extensive work in there yesterday, and did not see them. However, I do remember seeing a sub place under the right side bench on a showroom model withe the upgrade, and I do have a black cover, looks like a wiring cover) in exactly that area, so I'll pull that and see what I find!
Old 07-14-2005, 05:56 PM   #4
Westfalia's Avatar
Images: 35
No wires under the bed, although I did find a good deal of wasted space near the water heater that could be used for storage.
I looked everywhere I could around the wheel arch, including back under the fridge, no wires. I have absolutely no idea.
Still needing to look up front.
Old 07-18-2005, 03:29 PM   #5
Westfalia's Avatar
Images: 35
I was able to look up front, forward of slide out drawer under the right seat. I found power, ground, remote, and a L/R RCA cable. Score! Maybe I'll install a Basooka Tube sub behind the seat.
Now to find the other two. Is there a possibility that it is installed between the trim pieces where the rear TV would mount?
Old 08-14-2005, 09:15 AM   #6
Westfalia's Avatar
Images: 35
TTT. Still trying to find information regarding the wires for the TV wiring. Is there a possibility that the wires are hidden in the wall behind the coax outlet at the rear bed? I have pull the switch covers, but, I haven't found anything yet.
Old 08-18-2005, 11:04 AM   #7
Westfalia's Avatar
Images: 35
Followup:
OK, so I pulled off all of the plugs, including the 120V, out and off of the wall by the rear bed. Low and behold, behind the 120V plug that I didn't remove last time, there were the two wire sets: audio return and A/V supply from the front stereo. I plugged the audio cable into my LCD TV audio out, and then into my add-on XA-300 AUX adapter on the Sony stereo. Works like a charm and I have TV audio through the stereo!
The audio wires were wrapped helplessly around the 120V wires a few times, which is a BAD idea, as you can get inductive current flow, not to mention line noise. By unwrapping them, I was able to free up a few inches, and I will hopefully get a slightly cleaner signal. I moved their location down to the bottom cable outlet. I'll likely eliminate the cable/SAT bypass loop and plate, and make a plate specifically for the A/V cables with terminating female connectors.
Thanks for the help Bambi Bandit! Hopefully, this brief thread will serve as a guide for others that are wanting to upgrade their standard audio system by using hidden wires that Airstream (thankfully) added to most newer trailers during construction.
Old 08-18-2005, 11:18 AM   #8
Westfalia's Avatar
Images: 35
I almost forgot to post some obligatory pictures.
Old 08-18-2005, 12:37 PM   #9
Images: 12
Well I'll be darned
Funny yours was wrapped behind the AC... Mine was under the bed, but I think having there at the AC plug is better, so that you can pull it to the TV easier. I think I would have had to "fish" behind the wall and pull up the ends.
Now I've got to figure out where they are in my 28', and how I'm gonna wire that one...
UUgh.. too hot in TX to work on it now. Will wait till it get cooler.
Kevin
Old 08-18-2005, 04:02 PM   #10
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Chris,
I just read where your CCD is pre-wired, and you found the cables. That's fantastic, as you won't have to conceal any wiring. If I recall, the fuse panel in mine has a circuit/fuse for the subwoofer.
SilverRanger is offline   Reply With Quote
Old 08-18-2005, 04:19 PM   #11
Westfalia's Avatar
Images: 35
We'll have this puppy fully wired for surround sound and video in no time at all. We don't need no stinkin' drive in movie theater.
The sub will probably be the last part of the equation. I added some sound deadening in the cabinet housing the front speakers, and it took away a lot of the boominess. I will eventually install some better speakers at some point, further enhancing the bass.
Thanks for all the help SilverRanger!
Old 08-25-2005, 02:56 PM   #12
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Wires
You know i looked behind my stereo and found three sets of RCA wires also.I tried to see if they ended in the plugs but i did not see them.I will try and look again and mabey under the bed.Hopefully i will find them.Seems like this will be one modded out Airstream when i get done with it..
The cool part is that i can use my ipod in the car then transfer it to the Airstream.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 08-25-2005, 06:42 PM   #13
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Wired for sound...
I'm likin' the direction of this thread... have a 30' Classic that is wired with the standard Sony CD, AM-FM etc., etc.. Been told the wiring for the sub is beside the couch behind the breakers.The 4 speaker set-up (2 in the galley, 2 in the bedroom) leaves a lot to be desired for anything more than the weather channel... Do understand that the config is different between the Classic & CCD - had an International A/S before this one and it was set up pretty well... this one's a bit more,... peculiar.
What are y'all using for amping and speakers? Certainly not the standard equipment, right? Bi-amping your setup? What about insulation and sound outside your A/S? Doing external jacks (RCA or 1/4"?). Bambi bandit - understand your reluctance to work on the project dureing the summer here...
Jaxon is offline   Reply With Quote
Old 08-23-2006, 07:11 PM   #14
hookedonclassic's Avatar
Fond du Lac , Wisconsin
Sounds like each model is different because of the layout. Anyone with a new 34' with the audio upgrade that can tell me where the sub is located on the AV upgrade option. It'll give me an idea where to start looking for wires. I have only the standard Sony CD player.
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
hookedonclassic is offline   Reply With Quote
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Wires to nowhere Craig Electrical - Systems, Generators, Batteries & Solar 3 10-01-2002 07:03 PM
Stereo ALANSD General Motorhome Topics 9 09-30-2002 07:26 AM
Replacing Motorola Stereo montanaandy Electrical - Systems, Generators, Batteries & Solar 1 09-03-2002 06:44 PM
12 VDC Mystery roessler Electrical - Systems, Generators, Batteries & Solar 3 08-01-2002 05:20 PM
