Old 08-23-2006, 07:18 PM   #15
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Stereo
Mine is under the arm rest on the street side.But this is for the 2005 25'ss.
Would anyone know exactly where the rca hookupare for my Television.I was told that it could be where the fridge is and I will have to remove it to get to it.I am really hoping that it will be easier to get it than digging into the fridge area.Thanks All.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 08-24-2006, 06:32 AM   #16
2007 19' Safari
The Woodlands , Texas
Greetings Everyone,
I have found this thread to be most interesting...
We just picked up our new 2007 Bambi 19' last Friday. I am hoping to install a DVD / Flat Panel later on. What type of equipment (aftermarket) is out there for use in this application ? Is there a wiring diagram that possibly exists for us Do-it-yourselfers ??
64Vette is offline   Reply With Quote
Old 07-23-2007, 08:38 PM   #17
2006 31' Classic
Seattle , Washington
Located my subs under left armrest, rca in front bulkhead along with video, though I can't find video termination. Haven't found back bedroom but not looking very hard -- very happy that I will now be able to use my monitor from laptop at front bulkhead and run sound back to the head-unit..I'll probably just make a little mini plug line-in connector on front bulkhead. Now I can leave the stock head-unit alone and put the little bit of av budget toward some not so crappy speakers and perhaps an amp/sub.
jmd5602 is offline   Reply With Quote
Old 07-23-2007, 10:57 PM   #18
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, mine is the same as yours, but my question is: Does this connect the television to the radio for the purpose of useing the radio speakers for the television? I thought these wires were for a bass speaker in the arm rest and for the 10 disc CD changer. [which I don't have]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-24-2007, 04:33 PM   #19
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Somehow, found this thread again... starting reading from the top and realized I'd been here before... When looking at the audio/AV stuff I could add... I called Dave Schumann at Airstream and asked where the wiring was for my unit - not a problem. He told me where things began and ended so I could add to as needed. Most things are prewired for the dealership to add extras... Airstream obliges. Call 'em up!
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 07-25-2007, 07:05 AM   #20
2006 31' Classic
It doesn't connect anything to anything at the moment afaict. Its just a set of RCA plugs between the head unit and various places which allows you to connect componenets without having to run the wire. I'm not even sure what the original intent was as I haven't seen the av setup but in my case I'm going to connect my video source (laptop) audio out to the RCAs and then connect those as source to my headunit. Unfortunatly, the stock sony headunit apparantly doesn't take regular aux in, so I have to get this box to do that:
http://www.crutchfield.com/S-zdEk1xO...900&I=158XA300
Found it at a sony outlet for $59..has a USB in as well which might be useful.
Old 02-19-2008, 12:47 PM   #21
DandB^2's Avatar
2007 16' Bambi
Reno , Nevada
A/V Wires found
This is a great thread. Based on your advise I was able to find the A/V wires in the bedroom on my 16' 2007 Bambi CCD. My bambi only has two outlets, a standard AC plug and a combined 12V, coax, antenna booster outlet. I found the prewired A/V above the combined 12V , Coax Plug wrapped in tape.
I also tore into the Stereo console and added the ground loop back to eleminate the cd feedback. I had the Audio upgrade not the Video upgrade which included (Sony CDX-a251C head unit and AX-300). I ditched the CD changer for something more modern.
Here are links to the manuals for the sony AX -300
http://www.xplodsony.com/files/manua...ers_Manual.pdf
and the Sony CDX-a251C
http://www.manualshark.org/manualsha...4/pdf_2366.pdf
So now my question is - what is the best way to cut a hole in the
Aluminum wall so I can attach an A/V outlet? (What type of tool works best for cutting into the wall?)
D
DandB^2 is offline   Reply With Quote
Old 02-19-2008, 02:21 PM   #22
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
On the 25' SS the cables in the arm rest of the streetside of the sofa are in fact power and RCA to the stereo for a sub. I installed an aftermarket bazooka and it works great.
From what I understand the AV cables for the TV are in the fridge compartment on the 25' SS.
It's in the location on the Bambi because that I think is around where the TV is installed. On the 25' SS it is typically installed on the fridge wall facing the dinette.
Old 05-12-2008, 12:39 PM   #23
KGIII
2009 27' FB International
Garland , Texas
Chris, thanks for the awesome lead to this thread, posts, and pictures. Looks like you saved me atleast a day here. I am mounting a 19" Samsung LCD in our bedroom today. You have taken a good deal of fear out of it.
George
geogeczy is offline   Reply With Quote
Old 05-12-2008, 01:20 PM   #24
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
No problem! I'm glad that it worked for you.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 05-12-2008, 07:14 PM   #25
hookedonclassic's Avatar
Fond du Lac , Wisconsin
Originally Posted by geogeczy
\ I am mounting a 19" Samsung LCD in our bedroom today. \
George
George: Please post a picture when you get yours done. I like the 19" Samsung and may need to add one in our bedroom. What kind of hardware are you using. Thanks.
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
hookedonclassic is offline   Reply With Quote
Old 08-04-2008, 03:42 PM   #26
mountainboy's Avatar
2005 25' International CCD
Marshall , Virginia
Bringing up an old but usefull thread here...
I'm trying to find where my av rca wire ends up in my '05 International CCD 25'.
Some have said here that it is in the wall between the fridge and the dinette. Anyone know where exactly? If you got the av video upgrade where did they put the outlet for the rca jacks?
I have an AC recepticle and a cable outlet in the cabinet above the dinette (see attached "crappy" pic). I pulled both of those out and found a flat three wire back there but could not find the end of it. It was tight in either direction...seemed to be running from back to front. It looks like the same wire that ends up back at the stereo.
Has anyone found their wires in one of these models? Not sure if I want to just cut a hole and hope I find it you know? I also looked into the outside access for the refrigerator but could see no sign of it there either.
Dean
mountainboy is offline   Reply With Quote
Old 08-05-2008, 03:21 PM   #27
Marshall , Virginia
Btt
Old 08-06-2008, 09:11 AM   #28
Westfalia's Avatar
Images: 35
Unfortunately for you, it's probably between the fridge on the bulkhead wall.
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Wires to nowhere Craig Electrical - Systems, Generators, Batteries & Solar 3 10-01-2002 07:03 PM
Stereo ALANSD General Motorhome Topics 9 09-30-2002 07:26 AM
Replacing Motorola Stereo montanaandy Electrical - Systems, Generators, Batteries & Solar 1 09-03-2002 06:44 PM
12 VDC Mystery roessler Electrical - Systems, Generators, Batteries & Solar 3 08-01-2002 05:20 PM
