Old 02-14-2008, 05:32 PM   #1
DrPlay's Avatar
2006 25' International CCD
Freehold , New Jersey
Mounting televisions
Hello Streamers:
Want to wall mount a tv in bedroom (other side of closet) and another in the dinette (wall that has refrig on other side) in my 25'ccd. Is there any extra bracing that is required or can I just placed screws into the two walls.
BB
DrPlay is offline   Reply With Quote
Old 02-14-2008, 05:47 PM   #2
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
Mounted a 19" on an articulating mount in the living area. I didn't think the 1/2" ply would be strong enough so I backed the mount with a small square of 3/4" ply, glued and screwed and made sure the 1/2" ply wall was well attached to the trailer.
Hope this helps.
Greg
Roadtoaster is offline   Reply With Quote
Old 02-14-2008, 05:50 PM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
This subject has been discussed many times. a little search will result in many answers.
Michelle TAC MT-0
Sarah, Snowball
Old 02-14-2008, 06:30 PM   #4
DrPlay's Avatar
My apologies. I've just spent the last hour reading older and informative posts on the same subject. Be more careful next time.
Old 02-14-2008, 06:57 PM   #5
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
DrPlay,
No apologies necessary. Welcome to the forums. You may have noticed today is the 6th year this forum has been on line. Topics like the one you posted have been run to the ground and stomped on. The search function, as you have now found, is very helpful. If you don't find what you like or have a new twist, please, ask away. Give alot of detail and model, make of your camper and you will get answers.
Post some pic's of your new TV mount - others would like to see your work.
Mike
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 02-14-2008, 07:02 PM   #6
Keymar , Maryland
My apologies. I did not welcome you. Suffering from good pain meds...
Michelle TAC MT-0
Sarah, Snowball
Old 02-14-2008, 08:12 PM   #7
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Welcome to the Forum.
Are you mounting a flat panel HDTV or older unit?
I'm asking because yesterday on our public radio station they had a show on the digital TV change-over happening next year. A caller wanted the guest's opinion on what would be needed to receive HDTV in a trailer he had out on some property 50 miles from the city. Got a fuzzy answer.
Yet another can of worms for us to digest.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 02-14-2008, 08:30 PM   #8
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Send a message via AIM to Andrew Selking
If you see how Airstream does it you will see that they use about 7-10 size piece of metal to mount on the wall to mount the TV bracket on with lots of screw to distribute the weight. Hope this helps.
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
License plate mounting Krazyjohnny Exterior Restoration Forum 6 10-15-2016 02:05 AM
tv mounting katsix Audio, Video & TV 4 01-01-2008 08:01 AM
Jack mounting plate elbundi Jacks, Stabilizers, Lifting and Leveling 8 05-06-2007 10:08 PM
Television Mounting jrk247 Audio, Video & TV 5 08-28-2006 03:41 PM
Antenna Mounting niftypkg Electrical - Systems, Generators, Batteries & Solar 25 08-19-2002 06:03 PM
