Old 05-02-2010, 12:15 PM   #1
krlajwvater's Avatar
2003 30' Classic
mount joy , Pennsylvania
Mounting my 19" TV and dish receiver
Has anyone else made a mount like this? I have mounted my TV and receiver between the upper and lower cabinet in my 30' classic trailer. I am wondering if this will pull the cabinets loose while traveling, from vibration or flexing of the trailer, or any other problem that may arise. Eventually I plan on putting the wiring inside the square tubing.
Name:	tv mount 006.jpg
ID:	101662   Click image for larger version
Name:	tv mount 007.jpg
krlajwvater is offline   Reply With Quote
Old 02-13-2012, 07:33 AM   #2
dznf0g's Avatar
Oswego , Illinois
This is a good plan. I also saw, somewhere, the same theory and similar design made out of wood matching the interior of the trailer. If I ever mount mine, I will use this setup.
For now I just set my TV on the credenza and stick it behind the couch for travel (wrapped up of course).
"All I want in this life of mine..... is some good clean fun" - Little Feat
Old 02-14-2012, 05:24 AM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
It really looks like a nice piece of work!
Now that you've used it for a while, any comments?
Vaughan
vswingfield is online now   Reply With Quote
Old 02-14-2012, 08:18 AM   #4
2003 30' Classic
We are really happy with the results of this setup. I have put the wiring through the middle of the tubing, as not to be seen. The TV stays put while traveling and I put a piece of velcro around the receiver, to hold it on the shelf while traveling, we now have room on the cadenza top for other things. I really don't know what other changes I could have made, to make it work better.
Old 02-14-2012, 11:44 AM   #5
Thousand Trails Founder
Scottsdale , Arizona
Send a message via MSN to Damianmgk Send a message via Skype™ to Damianmgk
Still hoping to find out a source for this type of TV Mount - the post I cannot find, arms are everywhere
Damianmgk is offline   Reply With Quote
Old 02-14-2012, 11:48 AM   #6
1986 25' Sovereign
Plant City , Florida
That arm is made by peerless mounts. We just installed 1000 of these at my work. The post could be made by any competent welder. If you made it from 304 stainless it could be brushed to look like the exterior of a newer trailer.
ck21084 is online now   Reply With Quote
Old 02-14-2012, 01:10 PM   #7
SARGE/AF's Avatar
1997 34' Limited
1977 31' Sovereign
Greeneville , Tennessee
TV mounting problems
This is a really good looking set up, maybe you should patent it before someone else does. I would say you could make some money off them easily. The shelf area I have like that sets next to the stove top, this is also where the TV connections are, so if I mount it anywhere near there and then use the stove there is heat issues. I think I am going to have to find someone who does wood working and can make something that will hold DVR/CD player and the TV folds up inside the cabinet and it mounts to the wall.
Sarge USAF
WBCCI 2500
Good Sam Life Mem
NRA, DAV, PGR, DRA
SARGE/AF is offline   Reply With Quote
"Have dish, will travel"? Need your input on a simple mounting for satellite antenna Aage Audio, Video & TV 13 10-30-2009 08:34 PM
portable dish connect to satellite receiver? tsaxy Computers, Internet & Satellite 4 09-03-2008 09:59 PM
Mounting Sat Receiver. Location? TexZen Computers, Internet & Satellite 4 03-02-2008 03:00 PM
Mounting starband dish Smoky Computers, Internet & Satellite 1 10-25-2007 03:09 PM
2" Receiver at rear of Airstream? BeBop Hitches, Couplers & Balls 5 08-23-2004 09:13 AM
