Old 02-13-2012, 01:14 AM   #1
Thousand Trails Founder
2000 30' Excella
Bend , Oregon
Send a message via MSN to Damianmgk Send a message via Skype™ to Damianmgk
Mounting Flat Panel TV
I am a new 2000 Excella owner; just took delivery, so I naturally am excited to get going but could use some advise. Idid a lot of searching, but do not find specific suggestions for my questions:
  • I want to put a 26-30" Flat Panel TV on a mounting arm that would attach to the wall over the cabinet that backs up to the Dinette. Anything I need to do to mount to the exterior wall in this location?
  • does anyone have recommedations about Dish vs. DirectTV for a TT?
  • There are a number of Antenna options, what are the practical considerations about Room mount Kngdome, vs Portable automatic?
  • I cannot figure out how to get into the mounted box that holds the car stereo - I want to replace the radio/casette unit with a single DIN radio/CD player, but I am not finding out how to remove the unit.
  • the pocket-door wall between the shower and the bedroom is where I want to mount another flat panel. Is there anything I need to be aware of, or special instructions about mounting on what appears to be a thin wall?
Damianmgk is offline   Reply With Quote
Old 02-13-2012, 05:23 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums. Most car radios have mounting clips that have to be activated with a set of pins shoved past the face so you can slide the radio out.
Unless you are seriously wanting a huge tv, a 22" would be more than big enough in that small a space. You should try to slide a piece of 3/8" or thicker plywood behind where you are going to hang the tv mount. That will spread the weight and strain of the mount and tv over a larger area.
Old 02-13-2012, 07:15 AM   #3
krlajwvater's Avatar
2003 30' Classic
mount joy , Pennsylvania
This is how I mounted my 19" TV and Direct TV receiver. This has stood up to 20,000 miles of travel, since install, and no problems along the way.
http://www.airforums.com/forums/f450...tml#post844606
krlajwvater is offline   Reply With Quote
Old 02-14-2012, 12:41 AM   #4
2000 30' Excella
Bend , Oregon
This looks like a great solution. I did some preliminary searching but cannot source this 'post' type, full motion mount. Where did you get yours, or how did you find it?
Thanks for your help.
Old 02-14-2012, 05:12 AM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I think that if you read the first post there, you will see:
Has anyone else made a mount like this?...
(emphasis mine). It looks like a very nice piece of custom work. My guess is that the dimensions from the top of the credenza to the bottom of the overhead cabinet vary from trailer to trailer, requiring each post type mount like this to be unique
I've considered building something like that myself, but settled for making a modified credenza top and setting my TV/monitor on that.
Vaughan
Old 02-23-2012, 07:53 PM   #6
mefly2's Avatar
2015 25' FB Eddie Bauer
Dish network seems to be the most cost-effective for us and we are looking at the tailgater sat dish.
Univolt to Powermax Boondocker and FB-9 control panel on 1972 Ambassador davidlaxson Batteries, Univolts, Converters & Inverters 6 06-17-2012 04:53 PM
Univolt to Powermax boondocker with new FB-9 circuit panel davidlaxson Electrical - Systems, Generators, Batteries & Solar 0 01-24-2012 08:08 PM
120 AC panel Board (Help) Rust Electrical - Systems, Generators, Batteries & Solar 1 08-27-2011 11:47 AM
12 volt panel location kmoore Electrical - Systems, Generators, Batteries & Solar 5 08-24-2011 09:45 PM
Hybrid fuse panel pgr32e Batteries, Univolts, Converters & Inverters 1 07-14-2011 09:56 PM
