Old 02-05-2011, 05:11 PM   #1
star kitty's Avatar
1967 20' Globetrotter
denver , Colorado
Mounting A TV to End Cap
Hello.
I have removed the original 12 volt light on the curb-side end cap of a 1967 GT and have replaced it with a 12 volt adapter to power a TV. This will also be the foot of the bed. My thought was to mount a 12 volt flat screen tv with a wall mount in this area.
My question is this: is there a solid place to mount the tv in this area? There are not vertical rivet lines in this area, just horizontal. What kind of solid structure lives behind the fiberglass and aluminum walls? I am assuming the aluminum wall is not nearly enough support for the weight.
Thank you.
ID:	121538   Click image for larger version
star kitty is offline   Reply With Quote
Old 02-05-2011, 05:36 PM   #2
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Probably not, but how heavy is the flat screen tv?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 02-05-2011, 05:50 PM   #3
star kitty's Avatar
denver , Colorado
Haven't purchased one yet. It's just a thought right now.
Old 02-05-2011, 05:57 PM   #4
DanielB's Avatar
The weight will be the big thing. When the trailer is stationary it might be ok, but might not be ok if the trailer is bouncing around going down the road.
- Andrew Carnegie
Old 02-05-2011, 07:34 PM   #5
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
I understand what it is that you are trying to do! However, it's harder said than done! If it were me I would uses a 4" to 5" 14 GA of stainless steel and place it horizontally so that one end would attach to your front wood cabinet and the other end would attach to the wall rib or in this case door frame... It would run just above your old light position. The is no internal support inside the wall anywhere in that area!
Todd
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 02-05-2011, 09:36 PM   #6
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Purchase one of the super thin lightweight LED/LCd screens. I bought a 23" Vizio from Costco for $200 online. It is 2.5" thick and very lightweight to hang.
RichHog is offline   Reply With Quote
Old 02-06-2011, 07:02 AM   #7
star kitty's Avatar
denver , Colorado
Does it come with a 12 volt adapter or are those easy to find at say Radio Shack?
Old 02-07-2011, 08:14 AM   #8
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
No comes with ac wall wart that's external. Rad Shack probably has 12V adapters.
China toilet and rear end separation nukefamily Sinks, Showers & Toilets 0 02-01-2011 09:37 AM
Before I remove bath end cap Breadbug Ribs, Skins & Rivets 3 01-27-2011 01:03 PM
Aluminum end cap? Breadbug General Interior Topics 1 01-27-2011 09:54 AM
Keep or not? Interior end cap. Breadbug General Interior Topics 1 01-18-2011 04:42 PM
What is this part? (front end shelf) SpaceEgg General Interior Topics 2 01-09-2011 05:11 PM
