Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 05-29-2007, 04:37 PM   #1
Cstar
Profile:  2006 28' Safari SE
Columbus , Ohio
Images: 16
Mounting a 32" HDTV
I thought some of you might like to see my solution for the small screen sizes offered by the factory. So far everything is going according to plan. At some point I would like to add a rooftop dome satellite system but the tripod and portable dish will have to do for now. I did wire the connections from under the table to up by the edge of the TV.
Photos in My Pictures on this forum.
Cstar is offline   Reply With Quote
Old 10-16-2007, 10:10 AM   #2
KANEHILL
KANEHILL's Avatar
Profile:  Currently Looking...
Ellis Grove , Illinois
Where are you going to mount or place your sat. reciever so you can get a direct aim for your remote?
KANEHILL is offline   Reply With Quote
Old 10-16-2007, 01:12 PM   #3
Tim A.
Profile:  2002 19' Bambi
Lafayette , California
Our Bambi did not come with a TV, but we recently increased to a 23 inch flatscreen, which is much larger than what Airstream is presently putting into the 19' Safari. I thought it might be interesting for people to see the 4 pictures showing our solution to a larger screen. The TV is on a sturdy arm which allows watching from the dinette or the bed. For towing, a cover with a pad at the bottom and anchorage to the cabinet relieves the arm from providing much support. This has worked well over very rough roads.
ID:	47404  Click image for larger version
ID:	47406  Click image for larger version
Tim A. is offline   Reply With Quote
Old 11-10-2007, 05:22 PM   #4
Cstar
Columbus , Ohio
Images: 16
Kanehill
We have the sat rec. on a piece of plastic with an L shape that lifts it above the ledge in the upper cabinet. We just open the cabinet door to allow the remote to work.
CT
Old 11-10-2007, 08:15 PM   #5
2airishuman
2airishuman's Avatar
Profile:
wow ct...
that is a BIG tele!
i can tell you from first hand experience it will NOT say on the bed for long...
one fast lane change or emergency braking and, woosh, bang, boom!
use something tacky, like a rug mat or shelf liner stuff...
looks like a beefy wall mount too!
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 11-22-2007, 10:13 PM   #6
Cstar
Columbus , Ohio
Images: 16
2airishuman
You are correct, on one three day journey it did slide off the end of the bed once. No damage luckily. It is quite heavy and the weight of the set causes the mattress to move around more than the TV. So most of the time the mattress just might be moved forward to the edge of the front wall.
Right now we are using stretch cords and hooking them to the cabinet doors while in motion. Has worked so far. Next step is to attach hooks to the underside of the bed and use bungy cords to limit the movement of the TV and mattress.
We are still very pleased with the setup and find it amusing when people see how large a unit you can have compared to what is offered by the factory.
Corky
Old 11-23-2007, 09:36 AM   #7
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Just where do you put or mount such a monster?
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 11-25-2007, 10:21 PM   #8
Cstar
Columbus , Ohio
Images: 16
thecatsandi,
I have the pictures in a gallery of photos in my profile that can be accessed in the left margin. I will try to add them to this post.
Corky
Honda Generator Mounting dmac Our Community 11 05-20-2003 09:55 AM
Solar Panel Mounting JaceBeck 1999 Safari 2 02-26-2003 03:55 PM
Jacking points on '77 27' International johnmw Jacks, Stabilizers, Lifting and Leveling 13 12-13-2002 12:05 AM
LP Tank Mounting bracket kzener40 LP Gas, Piping, Tanks & Regulators 1 08-21-2002 04:40 PM
Antenna Mounting niftypkg Electrical - Systems, Generators, Batteries & Solar 25 08-19-2002 06:03 PM
