Old 05-15-2008, 07:27 AM   #15
Yup, would love to know how it works.
Another thing to consider is that the exterior isn't going anywhere-- so if you have items you need to work on for the INTERIOR to be campable, well, that's probably a better use of your time and it won't drive you nuts because you'll be able to FINISH certain projects. Then, if you get an extra hour here and there, work on the polishing as you have time.
Much easier to say than to do, though, since I've found that I have become part of the HGTV crowd who now expects complete home renovations to be completed within the span of 30 minutes...
Old 05-15-2008, 07:55 AM   #16
Mouse Nest Hunter
RoverOwner's Avatar
1961 28' Ambassador
Sherburne , New York
Frank - If you don't have any luck finding a replacement, I might be able to sand cast one out of aluminum for you using your piece for a pattern. I could even machine a slot into the bottom so it could be used as a bottle opener. Wally always said that every feature should have more than one function on these trailers.
I would be honored to make something for Anna.
RoverOwner is offline   Reply With Quote
