Old 02-08-2012, 10:17 AM   #1
KAYAKAMPERS's Avatar
1966 26' Overlander
Stone Mountain , Georgia
Looking for 2 speakers (or covers) for '78 Argosy
Does anyone out there have some of the speaker covers (or speakers with covers) that you are wanting to sell? Our 78 Argosy has the cream color plastic frame with a lighter brown fabric cover. Our speakers work fine now but if you're standing in the kitchen area or on the middle gaucho, you can't hear the stereo unless it is cranked up which blasts out the person on the front gaucho. So, we need two to mount on the kitchen cabinetry wall, so the brown ones would work also.
Let me know because I want them!
If not, suggestions on what others have done with speakers?
Thanks.
Beth
_______________________________
Beth Wallace & Chris Sanor
1966 26' Overlander International
Towed by 2016 Ford F-150
Tin Can Tourist
TAC #GA-27
AIR #34930
KAYAKAMPERS is offline   Reply With Quote
Old 02-12-2012, 07:22 AM   #2
1966 26' Overlander
$$$$$$$$$$$$$$ Not looking for free speakers
Just in case you thought I wanted them for free, I am willing to buy something! I can't believe no one out there has anything. So sad.
Tin Can Tourist
TAC #GA-27
AIR #34930
Old 02-12-2012, 07:34 AM   #3
Baltimore , Maryland
any chance you can post some photos of what it is you are looking for? I might have some for you. They are from the front end cap cabinet and live behind tambor doors. This is on a 71 Overlander, so a photo might help. I also know of a mid 70's Argosy being gutted out.
I am not soliciting business, these are on my "free to a good home" shelf..
Old 02-12-2012, 07:46 AM   #4
1979 Argosy Minuet 6.7 Metre
San Antonio , Texas
Beth,
When I purchased my Argosy a short time ago, I found 2 extra sets of speakers inside (not original,sorry). There was a hole in the wood of the overhead end caps (bulkhead?), and car speakers attached inside the cabinet. With the fabric upholstery covering the facing I didn't know the speakers were there until I opened the doors. There was also a pair of box speakers attached to the outside of the fridg cabinet and one one the pantry wall.
Good luck finding what you need or want!
Vicki A. is offline   Reply With Quote
Old 02-12-2012, 08:48 PM   #5
2004 16' International CCD
Orem , Utah
I just pulled 2 6 1/2 speakers in bed area previous owner custom built some cabinet I ripped it down. If I can come up with a solution and find 2 speakers with posts to mount off original bolt holes and figure out something to go over window I may have 2. I know this unit has $2800 upgraded stereo setup. If you want couple cheap speakers may I suggest searching marine 6 1/2s do froogle search. Picked some up for boat in black look nice sound ok not top line $17bucks shipped.
Provantage was there name search pyle speakers find some you like in marine
PROVANTAGE: Pyle PLMR-62 Pyle 6 1/2 inch 2-WY Marine Speaker System
starcraft is offline   Reply With Quote
Old 02-12-2012, 09:04 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
The speakers in my 1983 Excella are 5" speakers rather than 6". I replaced all four a few years ago. See http://www.airforums.com/forums/f450...ent-38596.html for photos, including the covers.
As I mentioned in that thread, the original speakers were incredible junk. Only two of the four even matched. Don't even consider looking for "genuine Airstream" speakers, at least from the old days. Good sets of speakers are readily available.
As far as those square brown covers in my photos, they are unique to Airstreams I think. You will have to scare them up used if that's what you need. I could use the outside trim that holds the grill in place (See post 9) for one of my speakers, myself. Just haven't tried to look for one.
Vaughan
Old 02-12-2012, 09:23 PM   #7
Ottawa , ON
If you want to shop for new speakers, IMHO there are two types of stores that carry them. The auto/boat stores, and the home theatre shops.
Generally speaking, I believe that the boat stores sell the same stuff the auto guys do, only they might be "toughened" for marine exposure, and have white trim panels.
The home theatre guys have units that are designed to be built into walls, and they are in general, selling better grade speakers, but they are really meant to go with better amplifiers than what are built into the car stereos that trailers usually have as systems.
I feel that a good car stereo shop is your best best. It is probably important to let them match you up a system, and more importantly, wire it into your TT in a way that will not hum or flat your battery because of the so-called "parasitic" connections car systems like to use for programming and clocks.
If you are not using a sub-woofer, I don't feel that it's important to have a lot of power, given the interior dimensions of most TTs. I also feel that many car stereo systems have an overly "bright" sound (too much treble) and this adds to the perception of "loud" quite a bit.
It's always important to bring along some music you will actually listen to and audition the speakers, if at all possible. Speaker specs are completely worthless IMO, and give no idea at all how they sound. Play them at realistic volumes and shop/audition during a quiet time for the store, if you can. You will be surprised how different even the best speakers sound from each other!
Old 02-12-2012, 09:54 PM   #8
Maniacal Engineer
barts's Avatar
Menlo Park , California
I'm quite happy w/ the Polk speakers I put in our tow vehicle recently; about $60/pair at Amazon. They're marine rated, which means condensation, leaks(!), etc. won't damage the speakers.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 02-13-2012, 06:56 AM   #9
1966 26' Overlander
Thanks for the info everyone!
Here are the speaker covers we have now. They are just a little over 6" square. The additional two will be mounted on our Argosy woodgrain aluminum cabinets in the kitchen area, so the brown frames and darker brown covers would be fine. Of course, we don't care about the "speaker" part of it but are interested in the outside cover. If the inside works too, that's good but not as important.
Thanks. Beth
ID:	150988   Click image for larger version
Tin Can Tourist
TAC #GA-27
AIR #34930
Old 01-06-2013, 08:00 PM   #10
1983 27' Excella
Houston , Texas
Beth,
Better late than never? I have a pair of covers with the dark brown frame. Let me know if you are still in need.
Chad
Spinnaker is offline   Reply With Quote
Old 01-06-2013, 08:18 PM   #11
Protohyp's Avatar
1977 31' Excella 500
Los angeles , California
Send a message via AIM to Protohyp
I have 4 of those
Protohyp is offline   Reply With Quote
Old 01-06-2013, 10:08 PM   #12
Protohyp's Avatar
I meant to say I have 4 of exactly what you need. Same color and condition.
PM me if you want them
Clipper, Land Yacht, Radio TV Speakers masseyfarm Audio, Video & TV 2 06-23-2013 10:49 PM
Looking at 24 ft. Argosy crunch27 Member Introductions 6 06-09-2013 07:46 PM
1972 Argosy Exterior Refinish billymyers56 All Argosy Trailers 47 02-04-2013 09:18 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
Vent covers and outside propane covers robwok 1960 - 1964 Overlander 4 02-09-2011 11:56 AM
