Old 12-19-2004, 02:13 PM   #15
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Expand search to include "Monitor Mounts"...
We added a Sharp Aquos 14" LCD TV to our trailer, and were put off by some of the extremely expensive VESA Mounts (as noted above, now three sizes of square hole patterns using metric machine screws to mount...) Picture is great though process to repeat setup and channel search is mildly painful...
In addition to expensive TV mounts, we found basic "U-Joint" wall mount (pivots left/right and up/down and locks in place) with about 3" standoff from wall at Sears and Fry's (Computer/Tech Superstores..) for under $34... These are often inarea of computer LCD Monitors, which have same rear VESA mounting holes and stands as TV's. If you need swing arms, swivels etc this won't work, but for us mounting on side wall of Fridge cabinet facing couch that was enough...
We tried to get Sharp to recommend power plug, since TV actually runs on 12V, and yet it comes only with converter/transformer to take 110v back to 12v, and they rather curtly told us the TV must be pluggged into 110v... I assume that is driven by need for pure and clean power without fluctuations from typical RV 12V system... We solved with $20 "Inverter" to plug into cigarette plug and convert 12v up to 110 at up to 100 Watts... Hook up laptop computer with DVD drive/player and we have complete TV and DVD system for 12 or 110v....
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 12-19-2004, 06:33 PM   #16
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
How or what do you do when the temp get's into the teens ???
My son called tonight and asked me if we had the LCD installed yet (haven't) and he says with the temp around 10 deg above tonight that's cold enough to break the LCD screen.
Garry
Old 12-20-2004, 10:47 AM   #17
Tinsel Loaf's Avatar
JBMcG
I made a heavy duty plug for the 12 volt power plug in our AS. Our transformer converts 110v to 14 VDC. I eliminated the transformer and the set works great on 12 volts DC. Just make sure that you use a 12 volt heavy duty plug and that it has a good connection in the wall socket. If you have a poor 12 volt connection your picture will not be as clear. We don't mount our LCD on a cabinet or wall because we put in a nice soft place when we travel. Sometimes we bring it inside to watch HDTV.
Tinsel Loaf is offline   Reply With Quote
Old 12-21-2004, 06:41 AM   #18
DEO
DEO's Avatar
West of Boston , Massachusetts
Garry
Garry,
I have the same concern, I have had the displays on my car radio's freeze. I am planning on getting an LCD but will remove it in the winter.
DEO is offline   Reply With Quote
Old 03-10-2005, 02:53 PM   #19
myboyburt's Avatar
1993 25' Excella
Beautiful , New Hampshire
Images: 12
Airstream LCD TV Wall Bracket
Originally Posted by Barkingspider
I'll try to post pictures of my set up when I get home. Consists of the following:
  1. Airstream wall bracket w/ integrated velcro tie downs - I upgraded the wimpy plastic wall stops that Airstream applies to the bolts w/ large threaded rubber mounts. (Think this was about $30 from A/S for the metal mount, $15 from A/S for the velcro strap, and $5 at Lowes for the upgraded rubber stops)
  2. Omnimount LCD Cantilever Wall Mount ($60 bucks on Ebay - retails for $120 at Circuit City)
  3. Panasonic 20" LCD - outstanding picture ($800 at CostCo, retails for $1099)
The LCD TV's maiden voyage will be tomorrow morning but I have absolutely no worries. The TV has almost no movement once it's it sinched to the wall with the velcro strap and any movement is absorbed by the larger rubber stops. I was amazed at the additional support these larger rubber feet added. Holding a 20 LCD TV snug to the wall is no small task - especially on an articulating arm. Airstream may want to take a look at the rubber stops that I'm using and add them to the current trailers and motorhomes.
Joe
Dear Barkingspider,
Could you please let me know if you are happy with the support given by the Airstream LCD TV Wall Bracket. And if possible would you please provide the part # as I cannot find it in the Airstream online parts book.
I have purchased a 17" widescreen LCD for our camper and I want to ensure it doesn't get damaged while we are in transit.
Thanks!
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 03-10-2005, 07:24 PM   #20
sarmimi's Avatar
2013 23' FB International
2005 28' International CCD
Petaluma , California
Images: 12
Has anyone considered using a widescreen laptop computer as a substitute for a flatscreen? My wife and I were considering mounting our 17" Sharp Aquos to the 28 ft CCD that we are about to purchase. But since I was planning to bring my Dell 17" widescreen Inspiron on our 6 + month trip anyway, we can consolidate the computer (with wireless Internet connection - we can go to a local cafe and hook up for free), flat screen TV, DVD player, mp3 player, digital photo editor, etc. all into one. And we don't need a mounting bracket - we can just place it on a shelf. And since it comes with a chargeable battery, we can still use it if we are off the grid for an extended period. And with the latest screen technology of 64MB Radeon X300, or an upgrade to to either 128MB Radeon or 256MB NVIDIA GeForce Go 6800, your desktop picture is as good as a flat screen (some people would even argue that the picture is better).
- Mike
sarmimi is offline   Reply With Quote
Old 03-10-2005, 07:47 PM   #21
Joe Z's Avatar
Originally Posted by myboyburt
Dear Barkingspider,
Thanks!
Sorry I don't have the part number but I'm very happy with the support. But remember I did add some additional rubber mounts to. I've found the rubber mounts on the ends of the bolts really let you snug the strap against the TV. I've been on a few trips since installing it and I absolutely love it. Doesn't appear to move around at all. There's also the cool factor of having your LCD TV swivel out once your all set up. Joe
Joe Z is offline   Reply With Quote
Old 03-10-2005, 07:48 PM   #22
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 53
[QUOTE=sarmimi]Has anyone considered using a widescreen laptop computer as a substitute for a flatscreen?
Yes, but we have not found a satisfactory tuner unit that plugs into the notebook's USB2 or F/W ports. Otherwise, there's no way to feed video into our IBM, HP, or Apple notebooks that will display on the notebook screen.
We like the consolidated unit idea. We always have our notebook computers with us.
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2003 GMC Sierra 2500HD CrewCab/Shortbed diesel
Hensley/Prodigy
gklott is offline   Reply With Quote
Old 03-10-2005, 08:07 PM   #23
myboyburt's Avatar
1993 25' Excella
Images: 12
Thanks! I'll contact my local Airstream dealer to get the part number(s). And I already have your improvements on my husband's "Honey Do" list (he is just thrilled).
Michelle & Leon
New England Unit
Old 03-10-2005, 08:51 PM   #24
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Michelle,
When you call, ask for Pete or myself..Vern
Good Luck,
53FC
ps..we've already had several request for this item..
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 03-10-2005, 09:50 PM   #25
myboyburt's Avatar
1993 25' Excella
Images: 12
You can expect my call!
Hi Vern,
You are the person I thought about contacting. I just didn't know if this was your "area" at the New Hampshire Airstream dealer. You can expect my call in the next day or two.
Thanks!
Michelle & Leon
New England Unit
Old 03-10-2005, 11:36 PM   #26
1984 29' Sovereign
Savannah , Missouri
Talking
Hi Vern,
Thanks!
myboyburt,
Pete is the one you should ask for, rightly so, as he's the Parts Manager...
But, if he's not there..I'll be more than happy to help..
Our's is a "team effort"...
Whenever he has questions, He comes to me..
Look forward to talking with you folks..
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 03-15-2005, 11:20 PM   #27
1984 29' Sovereign
Savannah , Missouri
The part number for the installation kit is"
Airstream's #111125
This will get you the TV bracket installation kit.
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 03-16-2005, 09:46 AM   #28
myboyburt's Avatar
1993 25' Excella
Images: 12
Thanks Vern!
Part is ordered (Yikes, it's a pricey enchancement) and "The Tube" will be in for service on April 4th.
Thanks for all your help!
Michelle & Leon
New England Unit
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
LP Tank Mounting bracket kzener40 LP Gas, Piping, Tanks & Regulators 1 08-21-2002 04:40 PM
Antenna Mounting niftypkg Electrical - Systems, Generators, Batteries & Solar 25 08-19-2002 06:03 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
