Old 02-07-2011, 03:20 PM   #1
2005 30' Safari
Tallahassee , FL
Jack Digital Over-the-Air Antenna
I have an '87 Excella and need to install an off-air antenna. Last year, King Controls introduced the Jack, which supposedly had better reception than the Winegard Sensar 4 (with or without the wingman addition). I saw mixed reviews on whether it produced better results, so I recommitted to the Winegard; HOWEVER, King is now producing a Jack that is permanently installed 12 inches high. No cranking up (and no forgetting to crank down) needed. This seems to be an attractive option, but has anyone put one of these on their Airstreams to date? Pictures of the Jack are included. I look forward to hearing what you "pros" think.
Tallytown is offline   Reply With Quote
Old 02-09-2011, 07:20 AM   #2
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
Tallytown, I'm interested to hear what you or anyone else knows about this. Here is a link to the antenna: JACK Aftermarket Antenna
UAPachyderm is offline   Reply With Quote
Old 07-10-2012, 09:00 AM   #3
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Here is a picture of an Argosy 20' owned by Jim Bounds at the Cooperative Motorworks. He has heard great results from the Jack antenna.
I currently have one in a box in my living room awaiting installation. I removed the old antenna last weekend.
I'll try to take pictures of the installation. The two challenges are:
  1. The antenna requires a 2" hole (larger than the original hole)
  2. I want the coax to be hidden and not run on the inside of the wall.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 07-10-2012, 09:35 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Does this antenna require a seperate power supply? Asking because the old antenna was removed from my trailer years ago and the hole was sealed over, not sure if the wiring even remains.
MICHAEL
Old 07-10-2012, 10:06 AM   #5
ViewRVs's Avatar
1977 20' Argosy 20
The coax runs from the antenna to the booster outlet similar to other set-ups. The 12v power goes to the wall plate.
Fred H.
Old 07-10-2012, 10:31 AM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
That's a contradiction in terms isn't it?
How do you propose to hide the coax without running in inside the wall?
Vaughan
Old 07-10-2012, 10:43 AM   #7
ViewRVs's Avatar
1977 20' Argosy 20
Yeeesh!
On the inside wall vs. Inside of the wall.
I knew that would come back at me! I just want the coax hidden. :-) My original antenna is pre-coax! I might try to pull coax through using the original wire.
Fred H.
Old 07-10-2012, 01:18 PM   #8
1983 34' Excella
1967 24' Tradewind
Images: 32
Yeeesh!
That's what I did on my Trade Wind. I used one of these Outdoor 75 To 300-OHM Matching Transformer with Weather Boot on the antenna itself. Works great.
My Excella was already coax from the antenna to the back of the wall plate. The wall plate had the two holes for 300 ohm flat cable to plug into. I drilled a new hold between them and the 12v outlet and mounted the coax directly there. You can see that in the photo.
Vaughan
Old 07-27-2012, 03:24 PM   #9
ViewRVs's Avatar
1977 20' Argosy 20
That is PERFECT! I was tinkering in the Argosy today and actually thought of this before I read the follow-up post! I am delighted to hear that it works!
I could see no easy way to run the new coax between the inner and outer panels. Airstream used some pretty stout wiring for that old antenna.
QUESTION: Would it be better to use a digital Antenna balun instead? I would need one on either side of the old antenna wire (one to the Jack antenna and the other to the wall outlet).
Fred H.
Old 07-27-2012, 03:33 PM   #10
ViewRVs's Avatar
1977 20' Argosy 20
I used a 2" hole drill bit to cut the upper hole. I used a spare 2x4 as a pilot to keep the drill steady.
The 2" drill bit would not work for the ceiling panel. I drilled a series of 1/8" holes, pried it out, and cleaned up the opening.
ID:	163966   Click image for larger version
Fred H.
Old 08-02-2012, 11:40 AM   #11
ViewRVs's Avatar
1977 20' Argosy 20
What did you use to fasten the antenna to the roof? Rivets or sheet metal screws?
Fred H.
Old 08-02-2012, 02:12 PM   #12
1983 34' Excella
1967 24' Tradewind
Images: 32
I'm not going to be any help here. I was just running coax to the original Skyliner on my Trade Wind, not going to a new antenna. I just jumped in on this thread because the problem with the coax was the same.
I've been watching the threads on the Jack with interest. I can see how it would be nice not to have to raise and lower the antenna. I would really like to see before and after results with a Skyliner to Jack conversion. Number of channels, sensitivity to direction, etc... My Skyliners work so well, that I won't be doing that comparison myself anytime soon.
Vaughan
Old 08-27-2012, 03:44 PM   #13
ViewRVs's Avatar
1977 20' Argosy 20
I was able to use a fish tape to pull the coax through the walls of my Argosy. Fortunately, I had the center fan and roof AC out so I had two additional access points! I added a new hole for the wall plate and used the adjacent 12v outlet for power. everything is up and running great! I have full digital signal on my local stations.
FYI - I tried to use passive closed circuit TV baluns to use the existing 2-wire antenna wire but I could not get enough signal strength to justify using it.
I am using my laptop to watch TV using the Averty USB TV tuner. In a 20' motorhome, everything needs to have multiple uses! I also connect the PC headphone jack to my dash stereo for better sound!
My roof project blog More pictures to come..
Avertv Hybrid Volar Max TV Tuner Kit for Windows MTVHVMXSK
Fred H.
Old 09-01-2012, 05:27 PM   #14
ViewRVs's Avatar
1977 20' Argosy 20
I have completed my Jack Antenna installation in my Argosy 20' motohome.
I did run new coax through the wall since my fan and AC units were already out. The old antenna wire could not be used to operate the antenna.
Here are some pics. I have painting scheduled for October 2012. This was one of my pre-painting projects!
ID:	167231   Click image for larger version
Fred H.
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
Cable jack options for exterior skin NicheVintage Audio, Video & TV 8 01-30-2011 06:20 PM
Radio antenna needed? SilverHoot Audio, Video & TV 25 01-19-2011 11:01 AM
Forced air heater on the go. Dr Dan Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-06-2011 07:30 AM
