Old 09-01-2012, 06:06 PM   #15
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Nice looking installation, and thanks for posting the photos. Were there any limitations as to how far away from skylights, A/C units etc the Jack antenna should be installed?
fltlevel510 is offline   Reply With Quote
Old 09-01-2012, 07:17 PM   #16
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
There was not anything in the installation instructions regarding location. I used the same location as my original antenna.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 11-09-2012, 08:34 PM   #17
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
I would like to know how well the new antenna works? Christmas is coming and the inlaws are asking what I want...Do I want a new Jack or not?
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 11-09-2012, 08:51 PM   #18
stowaways's Avatar
2007 27' Safari FB SE
1969 31' Sovereign
Ft. Worth , Texas
We recently installed Jack and are very happy with reception. Not to mention the fact that it requires zero cranking up and down! Go for it!
Sammie, Krystal, Lucas, Spencer & Jake!
stowaways is offline   Reply With Quote
Old 02-05-2013, 09:09 PM   #19
texasbound's Avatar
Bothell , Washington
Okay.. reviving an old thread here in hope of getting some help!
I have a 74 sovereign with an old skyliner that was long gone when I got the trailer. The "two wire" from the roof to the jack/outlet is there... can it be used for the Jack Anetenna or no?
I've tried pulling... and I didn't see anything budge on either end...
Help someone please!
-=TexasBound=-
1974 - 31' Airstream Sovereign Land Yacht "Dudley"
WBCCI # 7616
http://ismelltexas.wordpress.com
texasbound is offline   Reply With Quote
Old 02-05-2013, 09:22 PM   #20
ViewRVs's Avatar
1977 20' Argosy 20
I had the same thought with my 1977 Argosy MH and the answer is NO. I tried several different baluns and also called the company. I never got it to work. I was able to run coax while installing the Fan Tastic fan and fixing the AC installation.
Fred H.
Old 02-17-2013, 09:09 AM   #21
texasbound's Avatar
I recently installed the Jack HDTV with base model on my 74 sovereign. Works great! ! Couple things:
1) had to run new coax down fridge vent
2) mounted with butyl base, rivets, and then vulkem.
Pulled 12 channels from my "fringe" location, about half were hd broadcasts and looked fantastic on my 27" LED!!
Does anyone know if these are suppose to be turned forward when moving? Not sure if it matters. ....
-=TexasBound=-
WBCCI # 7616
Old 02-17-2013, 11:19 AM   #22
1994 30' Excella
Mississauga , Ontario
Looking at the posted photos I would think it is most aerodynamic if facing forward.
Al
Al and Jean
TAC ON-3
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
Cable jack options for exterior skin NicheVintage Audio, Video & TV 8 01-30-2011 06:20 PM
Radio antenna needed? SilverHoot Audio, Video & TV 25 01-19-2011 11:01 AM
Forced air heater on the go. Dr Dan Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-06-2011 07:30 AM
