Old 12-10-2014, 05:49 AM   #1
Alumitater's Avatar
2007 25' Safari
Spanish Fort , Alabama
JACK antenna on 07 25' Safari
Morning folks.
I recently purchased a Jack antenna system intending to replace the Winegard system on my Safari. I was looking forward to using the Jack built in signal directional system. That has been my primary complaint with the Winegard....it is very difficult to properly aim the antenna for consistent reception.
After looking at the placement of the factory Winegard system, it appears the mounting hole is located too close to the Heat Pump unit on the roof for the Jack system. Has anyone else encounter that?
As an alternative, has anyone utilized the Winegard signal strength system?
Thanks in advance!
Tom and Robin
2007 Safari 25' FB Twin
"If you have to go through a minefield....follow somebody"
Alumitater is offline   Reply With Quote
Old 12-10-2014, 05:53 AM   #2
Alumitater's Avatar
2007 25' Safari
This is the Winegard signal strength indicator I was referring to:
Amazon.com: Winegard RFL-342 SensarPro White TV Signal Strength Meter: Automotive
Tom
Tom and Robin
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
Jack Digital Over-the-Air Antenna Tallytown Audio, Video & TV 21 02-17-2013 11:19 AM
Jack for TV antenna outlet?? Help !!!! goldenlily Audio, Video & TV 4 10-03-2010 07:02 PM
antenna/cable jack lahrfarm Audio, Video & TV 2 02-12-2010 12:50 AM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
