Old 02-23-2008, 06:49 AM   #29
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Red face
"Sorry--I think I encouraged that"
Yes, sirree....you were the one! I got a little carried away between threads. You guys are too funny!
Anyhow, back to the antenna, I hope it all works out for you.
By the way, how do you highlight quotes in blue from previous posts? Can't seem to figure that out.
The cold, heartless one.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 02-23-2008, 06:55 AM   #30
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Hi Becky
You can select the type you want to change using your curser and highlighting it, then on the tool bar above the box you see a letter A, us the droip down and select a new text color.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-23-2008, 07:24 AM   #31
CanoeStream's Avatar
St. Cloud , Minnesota
Click on the 'Quote' link at lower right in the post you wish to quote. I went back and forth in separate windows with cut-and-paste to include quotes from both you and Dave in my post above.
The quote can be edited in your reply window like I did here -- including just the part I was addressing.
5 meter Langford Nahanni
Old 02-23-2008, 09:39 AM   #32
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Thanks - I'm sure it will. Who would have thought you'd luck into brand new 1970's antenna. Wonder if I could bend the splines so when it does stand up it will look like a moose's antlers.....
Old 02-23-2008, 09:48 AM   #33
Becky B.'s Avatar
1964 17' Bambi II
I'm not sure if that would be socially acceptable.
Thanks for the pointers on the quotes....got it!
Becky
1964 Bambi II
1988 Avion 32S
Old 02-23-2008, 09:53 AM   #34
Thanks - I'm sure it will. Who would have thought you'd luck into brand new 1970's antenna. Wonder if I could bend the splines so when it does stand up it will look like a moose's antlers.....[/
Becky, your quote terminators [/quote] have to be black. That prevents the intrusion of the coloring code in the middle of the terminator like occurred here - [/quote].
Socially acceptable? The mods aren't sleepin'...
Gary, sorry for hijacking your thread. Sounds like you worked into a very good solution!
Old 02-23-2008, 10:48 AM   #35
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Opps,
I went ahead and repaired the quotes in Becky's post above before I saw Bob's post.
It's what I do...
Richard
Old 02-23-2008, 11:34 AM   #36
Becky B.'s Avatar
1964 17' Bambi II
Originally Posted by azflycaster
Opps,
It's what I do...
Okay, now I got it! I think. Well, if I don't, some nice moderator will fix it! I won't say anything bad about moose again--I promise Mr. Moderator!
Becky
1964 Bambi II
1988 Avion 32S
Stay hitched or unhitch? starflyte1 Hitches, Couplers & Balls 17 12-11-2006 08:11 PM
Looking for yearly stay in Florida Daisy2 On The Road... 4 10-05-2006 10:32 PM
stay up late for the light show jpurdy Off Topic Forum 8 05-16-2003 02:09 PM
Where to stay - Berkeley, CA pjtaia On The Road... 2 08-17-2002 11:56 AM
Ouch! What happens when an Argosy MH meets the back of a dump truck 66TradeWind Airstream Motorhome Forums 13 08-12-2002 02:49 AM
