02-20-2018, 10:35 AM
#21
2002 30' Classic S/O
Fleming Island
Originally Posted by dasams
The OP said that he gets 4 channels while his neighbors get 20. This happens when you are too far from the towers and only get the channels with the strongest signals. This happens to us and is a separate issue from the LEDs or whether your TV's are wired correctly.
Nope, the LED dimmers and vent fans generate local noise which obscures the weaker signals. If his neighbors are getting more channels that is a clue that there is something wrong in his trailer.
Al
02-20-2018, 11:39 AM
#22
2017 25' International
Carlsbad
The fan in the shower also creates interference, maybe even more than the lights in my case.
02-21-2018, 08:03 AM
#23
Palm Desert
Nope? I also have the LED interference but that's old news. What is wrong is that the new antenna is not as effective as the old crank up model and it's not unusual to get less channels than your neighbor. This due to distance from the signal.
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
03-06-2018, 11:45 AM
#24
Opinionated newb...
2018 25' Flying Cloud
League City
, TX
Big question is whether anything can be done about it?
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
03-09-2018, 06:13 PM
#25
2015 30' Classic
Sherwood
, Oregon
Elevating the Winegard RoadStar
Getting ready to start the camping season, installed WiFi amp/router, cell amp and SureCall antenna. Found that the Winegard booster would not work behind the splitter from the new antenna (the manual didn't lie) so installed the two way splitter and raised the Winegard RoadStar antenna above the A/C. I cut the aluminum antenna base, sanded the ID on two 1" X 3" PVC to fit the antenna base, slid them on with Sikaflex and installed a set screw. The final step was to use a 1" X 6" PVC compression fitting to join the antenna base back together.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
03-11-2018, 09:44 AM
#26
2016 28' Flying Cloud
Brandenburg
, Kentucky
First off, like the notch in the ceiling for AS AC unit, second, wondering what the results of extending the antenna are.
03-11-2018, 10:02 AM
#27
Fleming Island
Unfortunately there are two posters' issues comingled in this thread and I lost track of which one you were responding to (actually you responded to both and I missed the clues). I responded thinking you were referring to:
"As I stated, when the LED's are off, I get perfect reception and many channels on the front TV only. For the rear TV, nothing works, I can''t get a single channel, no matter what I do. When LED's are on, either in rear or front (on low dimmer setting) the front TV then loses some channels and the signal becomes garbled/digitized, unable to watch at all. When I increase the dimmer to full intensity, either on LED's in back or in front, I lose all channels and signal on front TV."
But your response to him was he had a warranty issue - correct.
Mea culpa.
Al
03-11-2018, 10:26 AM
#28
2020 25' Globetrotter
Santa Rosa
Originally Posted by JeffC16
Just to be clear, the button is pushed in and the Winegard antenna is on for air/digital reception. It is NOT about being too far out in the boonies to receive or not receive reception. There is a serious connectivity issue in play here and the LED lights being on have something to do with it. As I stated, when the LED's are off, I get perfect reception and many channels on the front TV only. For the rear TV, nothing works, I can''t get a single channel, no matter what I do. When LED's are on, either in rear or front (on low dimmer setting) the front TV then loses some channels and the signal becomes garbled/digitized, unable to watch at all. When I increase the dimmer to full intensity, either on LED's in back or in front, I lose all channels and signal on front TV. Again, all other lights in trailer have no affect on TV receptions, only LED's. I love this trailer but Airstream has some splainin to do. HELP!
Apologies in advance for an obvious question, but have you run a channel search for the rear TV? One must be done independently for each TV. Another question: does the rear TV work with the HDMI (BluRay) input?
Mike
2020 25' Globetrotter Twin | 2024 GMC Sierra 2500HD Denali Ult. 4x4 Duramax
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
03-12-2018, 01:07 PM
#29
2015 30' Classic
Sherwood
, Oregon
We are 25 miles SW of Portland, OR and at the 800' level of the Chehalem Mtns. With the trailer in the garage I can get 41 stations with only four that pixelate. Before elevating the antenna I didn't count the channels but everything I tuned to pixelated. The real test, of course, will be on the road, but I am hopeful from the improved results of the limited test that it will have been worth the effort.
I cut 8" into 26" headers at the front of the garage and the photographed opening into the shop to clear the A/Cs.
