Old 10-26-2010, 07:29 PM   #1
Cottonwood Heights , Utah
Exclamation Is it the antenna or the TV?
This my first post on the forum. I need some guidance. I have 2006 25FB. I purchased the AS this summer and have been giving it some needed TLC. I need help with the TV antenna. There is a Winegard Sensar TV antenna with amplified signal. I checked the voltage to the antenna and it is good. I traced all cable and found it all in good order. The external run to the antenna is sun struck but other wise in good shape. I use both unboosted and the boosted signal option with equally bad results. I hooked up two different flat screen TVs to the antenna no picture or sound from any station. I connected a picture tube TV and got a few channels to come in. Of course when the AS is cabled to Comsat the flat screen TV is great. Why wont the flat screen TV work with the antenna? Is it the TV or is there something going on with the antenna I need to repair?
utah bob is offline   Reply With Quote
Old 10-26-2010, 07:34 PM   #2
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Welcome Utah Bob! The fancy flat screens usually need to be told they are connected to Cable or an Antenna. Look around in the menus to make sure you are set to Antenna and tell it to Scan for Channels...
newroswell is offline   Reply With Quote
Old 10-26-2010, 07:45 PM   #3
1986 31' Sovereign
Miami , Florida
There is also the remote possibility that the TV is analog. You might need a converter box for over the air broadcasts as they are now universally digital. Your Comsat translator does the conversion as a standard feature.
mike
Old 10-26-2010, 07:57 PM   #4
Images: 59
If the TV is digital, you won't get a snowy picture and scratchy sound like with an analog TV - it's all or nothing.
You don't say how far you are from the nearest broqadcast tower, but if you're more than 30 miles you might find a "Wingman" helps your reception.
I get much better reception using www.antennapoint.com and my iPhone compass. The "Wingman", whether it works or not, is a good direction pointer to use for aiming at the nearest broadcast power.
Old 10-26-2010, 08:57 PM   #5
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Hey Utah Bob, Looks like we got the same trailer and configuration. I've posted a lot of info on what I've learned on the Safari forum and then 2006 SE threads. Just tracked all this down yesterday installing a new HD unit.
Apple TV and Vizio:
http://www.airforums.com/forums/f48/...tml#post910864
First do you have the Sony Wega TV 15" Grey and square? If so you're hosed on the antenna issue becaude that TV doesn't have a DIGITAL tuner in it, only analog. Therefore since the TV broadcasters aren't broadcasting analog anymore then you will never get TV off that set without a "converter box". Not worth the money. Bought a Vizio 23" HD TV for $200. Here is the thread link on what I went through to replace the Sony:
http://www.airforums.com/forums/f335...i-70483-2.html
Good luck.
RichHog is offline   Reply With Quote
Old 10-27-2010, 09:48 AM   #6
Okay new day, 6 to 7 inches of snow in the Salt Lake area overnight - winter humbug!, down hill skiing soon to begin - winter fun! Thanks all for the help. I fiddled with the menu of the flat screen and found the source option changed from cable to something else and got several stations to come in with the antenna. Thanks for all the suggestions! Still not a great picture but now I know the antenna works fine. Now on to a solar panel installation and conversion to LED lights.
Old 10-28-2010, 08:03 AM   #7
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Please post your progress on that on the Safari forum, will be doing the same later on.
FM antenna? Zeppelinium Audio, Video & TV 14 12-30-2008 03:11 PM
AM Antenna Again niftypkg Audio, Video & TV 6 02-27-2007 10:29 AM
Tv Antenna Ray Pena Audio, Video & TV 8 05-24-2005 02:55 PM
Antenna silverlassie Audio, Video & TV 19 05-01-2004 01:02 PM
TV antenna davidz71 Audio, Video & TV 14 03-14-2003 08:14 PM
