Old 05-13-2010, 08:20 PM   #1
1973 23' Safari
Portland , Oregon
Is it bad to remove the antenna up top if I don't plan on using it?
The recent 23' Safari that I bought has an analog TV antenna up top. I'm sure it works, but I'll never use it. I get all my music and TV over the internet so the antenna is a relic for me. My question is, am I shooting myself in the foot by removing it? Will it all the sudden cause leaks or ruin my chances to resell it down the road? The entire rig is nearly original, but this antenna seems like dead weight to me.
Your thoughts are appreciated.
Biggysmalls is offline   Reply With Quote
Old 05-13-2010, 08:25 PM   #2
Kevin245's Avatar
We never used ours either so we removed it and patched the hole.
Kevin
Eleanor Roosevelt
Old 05-13-2010, 08:27 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
I've kinda been wondering the same thing, but I guess it doesn't do any harm, folded up up there.
Old 05-14-2010, 11:32 AM   #4
1973 23' Safari
Portland , Oregon
Here is a private message that I received. I'm not sure if this is a faux pas for posting someone's PM to me, but it contained such gold on how to do this repair, that I thought others might also be interested.
Hey Biggie,
It's no problem to remove that antenna. Just be sure that you take off the base plate as well.
You will have a 2" hole thru the roof of the trailer. You can get a square of white finished aluminum at least 2-3" larger all around to place over the hole.
If you have no intention of ever removing it again, use Sika-Flex 221 for the sealant. Run a couple of beads around the inside edge of the patch and also around the hole in the roof. It would help if you pre-drilled your rivet holes before you started using the sealant.
Then place the patch on and line up the rivet holes. Secure with rivets about every 2-3". After placing the last rivet, use Sika-Flex 715 to seal over the rivets and around the edge seam.
You will have an absolutely bomb-proof seal that will NEVER LEAK and never come off!!!
Let me know if you have any questions.
Old 05-14-2010, 12:11 PM   #5
1976 25' Tradewind
Erie , Pennsylvania
I removed my antennae off my 76. Actually I forgot it was up there and didnt clear enough space to drive into storage Anyway I intially took off the antenae and left the base plate on in case I ever changed my mind. Big mistake!!!! I thought I had it all sealed up until the first big rain hit and I realized I didnt seal it well enough. After that we pulled it all off and patched the hole and removed the lever on the inside and patched that as well. Now no leaks!!!
rollingbubel is offline   Reply With Quote
Old 05-14-2010, 12:21 PM   #6
_
Originally Posted by Biggysmalls View Post
this antenna seems like dead weight to me...
at ~ 10 lbs it's hardly any weight.
and it works FINE with digi signals so it's not out of date.
i DO think this hurts the resale value (for those who KNOW about it)
since the NEXT buyer would need to UNDO your improvement.
the wiring includes a tiny amplifier in the wall as well.
just leave it alone.
while i also use the web for tele, the batwing still comes in handy...
the main shaft can be used for mounting a broadband antenna that is RAISED for use..
and it can be Plugged into the puter for LOCAL programing and it's protective.
3 months ago a LIMB fell from a tree OVER my stream....
the antenna was UP and deflected this big branch away from the end cap which would have been mooooshed badly.
the bat wing bowed but did not break and like a member of the secret service...
gave itself to protect the presidential palace...
cheers
2air'
((in additon to patching the roof, there will be an INTERIOR hole to cover ...))
Old 05-14-2010, 02:03 PM   #7
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Au contraire!!
Biggy didn't say what YEAR his 23' Safari is, but if you have an old 70's "Skyliner" antenna, it is probably leaking. The pot-metal base reacts w/ the aluminum skin and slowly corrodes, eventually to the point of creating small (invisible) pin-holes in the plate, allowing the water in. The o-rings on the shaft can dry out, as well...also allowing water to pour in. (that was the case with mine...although, I couldn't prove the exact point of entry until I dropped the ceiling panel, and watched while the W poured water on the roof w/ a garden hose).
I repaired it pretty much like "the mystery pm-er" said. Except, I bought a small sheet of aluminum from Home Depot, and planked the base-plate of the old skyliner down on it...traced around it to get a matching size patch. I also marked the locations of all the rivet/screw holes, and pre-drilled them into the patch, so it was easy to install. I also sanded out the corrosion on the roof skin, to keep that from progressing. Lots of sikaflex and rivets into the original holes...it ain't gonna leak no more, no more.
Now, I only have to worry about the replacement antenna, which had to be installed in a different location. (new "BatWings" are longer than the old skyliners, and won't fit in the top/dead-center location of the original. had to install it "off-set" from the centerline, so it wouldn't interfere w/ the air conditioner. )
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-14-2010, 02:41 PM   #8
1973 23' Safari
Portland , Oregon
All-
Thanks for the excellent information. I've apologized original person who PM'ed me the info and the moderators were able to clean up my mistake by removing the person's identifying info. Lesson learned!
For what it's worth, I have a '73 Safari 23'.
Old 05-14-2010, 03:06 PM   #9
_
...For what it's worth, I have a '73 Safari 23'.
that's a game changer, ditch the coat hanger...
and PUT ON a batwing
bada dada dada dada dada dada batwing!
cheers
2air'
Old 05-14-2010, 04:46 PM   #10
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
You'll need to do it like this:
try and put it a little bit further forward than I did. Now, they have an attachment thingy that sticks out of the side of the antenna head, to help improve digital signal reception...that would interfere w/ my center vent.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 05-14-2010, 04:55 PM   #11
Road Ruler's Avatar
Images: 38
Good ideas guys. I've seen enough here to want to take our old anteni off and rivet in a patch. Many Thnxs.
Old 08-22-2010, 12:48 PM   #12
Rosie the Riveted
Ken & Janice's Avatar
1975 27' Overlander
Balfour , BC
I have a 75 Overlander and was wondering what the original antenna can do. I have a friend in the communications industry who tells me there is no such thing as "free tv" as of a couple of years ago so we were thinking of replacing it. With what ?
Ken & Janice is offline   Reply With Quote
Old 08-22-2010, 12:53 PM   #13
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
No offense, but your "friend" must have been trying to sell you cable.
The original antennas work perfectly for over the air HDTV, and there still is no charge. I use mine every day.
Vaughan
Old 08-22-2010, 03:11 PM   #14
If you have a 31' from the 70's style (skyliner), you can put the Winegard replacement on using the existing large holes and cradle with clearance for everything. It will also cover the rivet holes from the old mount. We removed the center ceiling aluminum just enough to reach it in order to run the coax cable down which was the only painful part (hard to get it back in its groove). We were able to fish the coax down along side of the vista view (curbside) and then fish again down to the bottom and out.
The Skyliner on ours had broken every plastic piece on the top portion and all the gears in the lifter. We tried out the new one using the digital converter at our first camping weekend and got about 25 stations (we were about an 2 hours outside DC). Some of the stations were Japanese and Vietnamese though.
Old antennae during removal:
New antennae in cradle:
Inside with roof removed:
How to remove the antenna cover... Skamper1 Audio, Video & TV 0 03-18-2010 02:54 PM
Remove Antenna Crank bwaysteve Phone, CB & Ham Radio 3 01-15-2010 03:21 PM
TV Antenna - Would you replace or remove it? vhord Audio, Video & TV 35 05-18-2009 10:20 PM
How? remove top interior skin Zeppelinium General Interior Topics 3 03-03-2006 03:25 PM
Want to remove antenna. Happycampers Audio, Video & TV 7 04-20-2004 07:00 PM
