Old 08-22-2010, 06:52 PM   #15
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
If you have a Skyliner like I do, there is no need to replace it with anything. They work great. That is assuming that you still have all the aluminum parts. Plastic parts like the gears and cover are available at TV Radio Satellite Parts : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!.
I've never compared them, but I have difficulty believing that a smaller antenna, like a batwing will match the performance of the Skyliner. Just my opinion. If I didn't have a complete Skyliner, I'd not hesitate to use a batwing. I just don't see any reason to replace an antenna that works perfectly.
Vaughan
vswingfield is online now   Reply With Quote
Old 08-22-2010, 07:58 PM   #16
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
unless...the situation I mentioned earlier in the thread. and not all of the parts are available. The innards that I needed are not.
They do work great. But I did find that the batwing actually picked up a couple of stations that I wasn't able to pull in w/ the skyliner, tested with the same amplifier in the same spot in my driveway. I was surprised, too.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 08-22-2010, 08:03 PM   #17
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I concur the Batwing is better. I think is because the amplifier is in the head of the unit and does not suffer the loss of low level signal coming into the trailer to reach the amplifier mounted in the wall used by the coat hanger antennas.
Old 08-22-2010, 09:11 PM   #18
1983 34' Excella
1967 24' Tradewind
Images: 32
Thanks Chuck,
It's good to have info from someone who had actually used both. I'll keep it in mind if I need to change sometime.
Vaughan
Old 08-23-2010, 06:58 AM   #19
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
mine doesn't have an amplifier in the head of the unit; I had already purchased the wall-mounted one (has the co-ax connector, + a 12v outlet, and cable/antenna inputs) to use w/ my skyliner. So when I decided that I needed to replace the antenna itself, I opted for the non-amplified unit. (~30 bucks cheaper, at the time...and the wall-mount amplifier also cost ~$30...so, same investment in the end.)
Air:291
Wbcci: 3752
'73 Safari 23'
Old 08-23-2010, 07:14 AM   #20
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
As far as interfering with the center vent, I used the original antenna hole and installed the batwing so it stows at an angle off centerline and lays down between the center roof vent and fridge vent. I have not had any problems. You can also shorten the antenna mast so it stows further forward.
Old 08-23-2010, 04:57 PM   #21
Rosie the Riveted
Ken & Janice's Avatar
1975 27' Overlander
Balfour , BC
Thanks everyone. We're going to try set up TV by Skyliner as it's in good shape save for some cracks in the insulation (taped it for the try). I found an interior antenna connector at the local electronics shop so we'll keep you posted as to results.Thanks again.
KC
Ken & Janice is offline   Reply With Quote
Old 10-03-2010, 07:11 PM   #22
1978 29' Ambassador
me , Texas
Biggysmalls,
Can you tell me how you get tv over the internet?
qratio@gmail.com
qratio is offline   Reply With Quote
Old 10-04-2010, 09:37 AM   #23
1973 23' Safari
Portland , Oregon
There are a ton of resources for streaming tv content over the net. Hulu.com is totally free and has a big collection of content. Netflix.com has an $8.00/month stream as much as you want account. You can download individual episodes from itunes and watch them later for about $1.00/episode. And there's lots of not so legal options like the pirate bay and other torrent sites that you can find on google.
Biggysmalls is offline   Reply With Quote
How to remove the antenna cover... Skamper1 Audio, Video & TV 0 03-18-2010 02:54 PM
Remove Antenna Crank bwaysteve Phone, CB & Ham Radio 3 01-15-2010 03:21 PM
TV Antenna - Would you replace or remove it? vhord Audio, Video & TV 35 05-18-2009 10:20 PM
How? remove top interior skin Zeppelinium General Interior Topics 3 03-03-2006 03:25 PM
Want to remove antenna. Happycampers Audio, Video & TV 7 04-20-2004 07:00 PM
