Old 04-07-2015, 03:12 PM   #1
interstateflyer's Avatar
2017 25' International
Los Osos , California
Is 12v TV with AC Adapter Necessary
I'd like to replace the Samsung 22 inch TV in my 2014 23D with a larger screen size model. I noticed that the current TV has a 12 volt input connected to an AC/DC adapter.
It appears that the TV only runs when there is AC available, either from shore power or the inverter.
So is there any reason why I should buy a 12v TV. Samsung doesn't seem to offer a 12v model larger than 22 inch?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 04-07-2015, 03:19 PM   #2
Boxite's Avatar
2008 22' Sport
If you purchase (or make) a cigar-lighter adaptor plug, you can run it on your 12V battery! (which is why I bought a cheap 19" from WallyMart, along with a 12V SONY bluray/dvd player.)
Old 04-07-2015, 03:38 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My Insigna 22 inch came with both an AC plug and a DC plug. If yours didn't the DC plug is simple to make.
MICHAEL
Old 04-07-2015, 11:42 PM   #4
Good suggestions, thanks.
Old 04-08-2015, 10:43 AM   #5
Mission Viejo , California
Just a warning, many RV's have converter/chargers that put out over 12 volts and not always a 'clean' DC. Solar systems can as well.
Many 12 volt TV's can be damaged by over voltage or noisy DC.
I had to put a 12 volt regulator/stabilizer on mine because the 14.2 volts from the charger blew fuses and actually melted the plastic plug connector. Now I have clean and stabile 12 volts for my electronics and don't need an inverter.
Bill Lynch is offline   Reply With Quote
12v
Torque wrench..necessary? Kistler Wheels, Hubs & Bearings 20 08-01-2016 06:15 PM
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 03:40 PM
is a rock guard necessary? flyingcloud Rock Guards, Segment & Window Protectors 33 07-28-2005 03:28 AM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
Are drain valves necessary? nickcrowhurst Fresh Water Systems 9 11-26-2004 07:37 PM
