Old 02-15-2010, 03:27 PM   #1
1976 31' Sovereign
1963 16' Bambi
1971 21' Globetrotter
Marbletown , New York
Interference in new Radio
My 8 track has never worked and I finally purchased a new JVC KD-S15, CD Receiver. The Radio is probably middle to low-end piece of equipment. I installed it this past weekend and, of course, everything did not go perfectly. I am powering the A/S with a Honda EU2000i Inverter Generator. When I hooked the radio up I used the original wiring for the Power, Ground, Antenna, and Speakers.
I turned the Radio on and the Display started flashing. In the mean time the temperature in the A/S stopped thematically as normal. When the furnace stopped, the display on the radio stopped flashing and I could barely hear 1 or 2 radio stations. I thought it might be the original antennas contacts being dirty/corroded, and cleaned them up Ė no difference. The next thing I did was to take 2 test leads and connected them from the radio leads directly to the Fuse Panel Ė no difference. Next I brought the 12-volt battery in from the garage and hooked it up directly to the radio. It worked beautifully!
Before I tried the battery I never checked to see if the CD or my I-pod worked. They performed well when the battery was powering it.
After it was running smoothly I found that 3 of the 4 speakers worked. When I touched the wires to the 4th one ( street side rear) I got a loud buzzing. I left it disconnected.
Iíve come to the conclusion that Iím getting some sort of interference from the Generator or Univolt. I donít know if Iím right and if I am, how do I deal with it? Iím not an electrician so if you have an idea, please speak the language of the verbally challenged.
Stone Ridge is offline   Reply With Quote
Old 02-15-2010, 05:15 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I would suspect a bad ground at the antenna or radio.
Try a temporary jumper wire from the radio to the trailer any bare metal ground should work as a test.
Garry
Radio Speakers but no Radio 1969 ???? tdoescher 1965-1969 Sovereign 13 04-21-2015 01:17 PM
cb radio, cassette radio jagcb750 Classic Motorhomes 14 04-19-2012 02:32 PM
Electrical & Radio Interference Questions Ganglin Lights - Interior & Exterior 3 07-19-2009 08:48 AM
Sony MEX-R5 head unit causing WiFi interference silverback Audio, Video & TV 1 05-24-2009 01:24 PM
Hitch Interference Camp-Dog Hitches, Couplers & Balls 14 12-13-2004 03:56 PM
