Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 04-23-2018, 07:16 PM   #21
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Woodfox45 yup. I found a pretty good deal on the camera and will install it myself. That’s why I’m looking for info on how airstream does it.
2019 Ford Expedition Platinum
Old 07-08-2019, 02:28 PM   #22
Temple , Texas
I just completed the install after stressing about it for over a year, I removed the light and left it off. There was plenty of slack in the wiring to spice in the camera. entire process took less than one hour. Thank you for the advise in getting this job done.
2014 Flying Cloud 25FB
2018 Ram 2500; Cummins
Blue Ox WDH
RamRider is offline   Reply With Quote
Old 03-23-2021, 06:29 AM   #23
Essex , CT
This is awesome. The lights in the back. Is there always power to them or do they work as brakes, where lights and power go in only when engaged. Sorry this is a bit of a newbie question!
AnAirstream is offline   Reply With Quote
Old 03-23-2021, 10:10 AM   #24
Essex , CT
Do the rear lights have power even when not braking or backing up? Thanks so much for this post!
Old 03-23-2021, 12:43 PM   #25
Mollysdad's Avatar
The clearance lights come on with the headlights/parking lights. Once on the camera has power.
Originally Posted by adobehome View Post
Has anyone used this, or another, to help line up hitch ball to connector while hooking up alone, without benefit of another human to guide you?
Most modern pickups have a backup camera in the tailgate. That gives you good L/R alignment but can be hard to judge front/rear.
I considered this camera for temp use. It mounts with a magnet and is linked to your phone. Plop it on the outer bumper and aim at hitch. Just remember to take it off before driving away. Amazon
$145
Old 03-23-2021, 12:59 PM   #26
Mollysdad's Avatar
Originally Posted by Wayne&Sam View Post
Molly’sdad that’s where I have my current camera and plan to try that first. I had concerns about the reception too. Maybe the line of sight through windows will do the trick
After two years, I love the camera inside the rear window. No weather, power is easy to find. I used the Garmin BC-30 to my Garmin RV 770 GPS. It's bluetooth. I'll say the signal is rock solid even working it's way out of the interior, through the front window, I'd guess. However, the resolution of the camera leaves a lot to be desired.
So, I've just ordered the HaloView 7108 camera and 7" monitor. I'm going to use the same inside mount for the camera.
I'll be adding another monitor up front, but I'll share the RAM mount that supports the TPMS currently. (More fun with RAM gadgets)
It will be an experiment to see if the Wi-Fi signal gets out of the trailer as well as the bluetooth did. I never seem to do things the easy way.
I'm going to keep the BC-30 aimed at the rear bumper. I'll piggyback it on the Haloview bracket. It's tiny and the GPS is there anyway. I like knowing how far I can back.
Old 03-23-2021, 01:07 PM   #27
Steamy1's Avatar
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
Alternative to drilling a hole
I chose not to drill a hole in the end cap and instead mounted the camera on a piece of aluminum angle attached to the top frame of the rear window. Connected the wiring to the license plate light feed.
Name:	Rear Camera.jpg
Steamy1 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Gleverett
Voyager Wireless Backup Camera dmilem General Repair Forum 2 10-17-2017 05:16 AM
Voyager wireless camera DeltaRon Electronics & Connectivity 6 06-16-2015 06:32 PM
Wireless Backup-Camera campadk Electronics & Connectivity 31 11-29-2010 08:32 AM
Wireless Backup Camera for Your Bambi campadk Electrical - Systems, Generators, Batteries & Solar 39 07-23-2007 07:08 AM
Wireless backup camera gklott Electronics & Connectivity 5 01-11-2005 12:23 AM
