Originally Posted by Wayne&Sam
Molly’sdad that’s where I have my current camera and plan to try that first. I had concerns about the reception too. Maybe the line of sight through windows will do the trick
After two years, I love the camera inside the rear window. No weather, power is easy to find. I used the Garmin BC-30 to my Garmin RV 770 GPS. It's bluetooth. I'll say the signal is rock solid even working it's way out of the interior, through the front window, I'd guess. However, the resolution of the camera leaves a lot to be desired.
So, I've just ordered the HaloView 7108 camera and 7" monitor. I'm going to use the same inside mount for the camera.
I'll be adding another monitor up front, but I'll share the RAM mount that supports the TPMS currently. (More fun with RAM gadgets)
It will be an experiment to see if the Wi-Fi signal gets out of the trailer as well as the bluetooth did. I never seem to do things the easy way.
I'm going to keep the BC-30 aimed at the rear bumper. I'll piggyback it on the Haloview bracket. It's tiny and the GPS is there anyway. I like knowing how far I can back.
