Old 03-06-2007, 12:36 PM   #71
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Bob, does yhe TV have a grounding plug on it? If so, try a cheater three pin to pin plug and don't hook up the ground. What you are describing sounds like a ground loop problem.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 03-08-2007, 09:17 AM   #72
2007 25' International CCD
spokane , Washington
feedback hum
Thanks for your post. The TV does not have grounding plug. Maybe I will just have to disconnect the woofer when drycamping. A technician suggested wiring the inverter directly off batteries. I have asked three auto/rv audio shops about this and interestingly, no one has heard of the problem even though they do say the majority of RV's do have an inverter set up for their TV's/VCR's/DVD players. Appreciate your thoughts.
bobf is offline   Reply With Quote
Old 04-08-2007, 07:13 PM   #73
2000 34' Limited S/O
Jamestown , North Carolina
Adding TV tuner to laptop
I was reading some older posts regarding optioins for TV,DVD,PC Monitors etc.
I will have my Dell laptop with DVD built in when we travel as I will work some remotely. How do I add the TV tuner to my laptop?
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 04-08-2007, 07:44 PM   #74
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
You plug one end of this into your laptop, the other to a TV cable connected to your Airstream's TV antenna, and install the software. Instant digital TV. Our Dell notebook has a 15.4" 1920 x 1200 resolution screen and was absolutely eye-watering on 1080i (or even 720p) stations with a USB HDTV tuner... until a lightning strike near? the antenna took it out (without hurting the notebook because it was in a powered USB hub, not directly into the notebook). You can typically change channels, pause, rewind, or record with most software (not sure about that included with this product). I used "BeyondTV4 for ours.
El Gato sells one identical to this for Macs, with their EyeTV software. I'm going to get the El Gato for the Macs, and see if it will work with the Hauppauge 950 drivers on the Dell. Someone on the AVSforum is using a Hauppauge with El Gato software on a Mac.
[edit] I guess I should add watching live HDTV takes a decently fast hard drive (ours is 7200 rpm) and processor (ours is a 2.0GHz Pentium M and about the minimum... a dual-core would be better). When watching live HDTV, it's written straight to the disk without decoding (for pause/rewind, etc), but for playback has to read it back off the disk and decode it, which can be processor intensive. So the disk can be pretty busy reading and writing at the same time. No way around that I'm aware of. Recording off the air and playing back later is a little easier on the notebook.
Maurice
Closed my DVD store - what about.... Tom Randall Off Topic Forum 3 01-27-2007 03:47 PM
The Long, Long Trailer toddster Airstream "In the News" 4 05-02-2006 11:11 PM
which vcr/dvd maznblu On The Road... 13 11-01-2002 08:14 AM
