Old 06-09-2006, 09:01 PM   #1
1968 20' Globetrotter
Houma , Louisiana
installation of new radio system in 68 GT
I would like to install a car stereo system in my 68 Globetrotter. Where is the best place to make the electrical connections?
mimibeth is offline   Reply With Quote
Old 06-09-2006, 09:41 PM   #2
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
Look above your dinette/gaucho at the front of the coach. There should be a cabinet/locker up there. Open it and look in. There ought to be a black wire poking out of the wall. That's a 12vDC source. Hook in there and set your radio where you want.
If there's not a wire there, look for your "control panel" if you have one. Usually above the fridge. There should be a 12vDC wire in there that you can tap off of.
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 06-09-2006, 10:30 PM   #3
1992 34' Limited
Falls Church , Virginia
Speakers??
Mimibeth -
I used to have a bit of a side job in HS, of installing Car Stereo units, speakers and the like. In cars.
If your GT has the speakers in it already, then I would say that you are in business. If not, then I would get a boombox or the like and use that.
Running speaker wires to the speakers, within the walls will be a nightmare. Running them along the floor/wall junction will probably be OK but then you have the issue with getting the speakers connected - likely unsightly if wiring is surface mount. Also, there is likely little if any room for speaker boxes or the like - and retrofitting into the wall/ endcap will be a big job.
It all can be done, mind you. A boom box might be a better choice however. Portable too!
My .02 cents.
Enjoy that AS!
Axel
SilverToy is offline   Reply With Quote
Old 06-10-2006, 07:50 AM   #4
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Mimebeth,
Let me express my ignorance here. Does it already have speakers in the wall and an outside antenna? My 75 Argosy has four speaker wires and a 12 VDC connection coming to the front overhead compartment on the streetside. It would be easy to add an automotive radio there.
Lamar
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 06-10-2006, 08:11 AM   #5
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I did the same to mine. I found the 12v wires in the front cabinet, and holes ready for speakers at each end of that cabinet. I installed a couple 6x9s stolen out of my truck in the holes, and a nice Alpine in a homemade box hooked into the 12v, and I've been enjoying it for the last couple years. The mounting box has a big switch for turning the power on and off to the radio, but the memory line is hooked up to 12v also so I don't lose my settings.
There is also an antenna on the trailer already, and I had to drill a small hole in the bottom of the cabinet to bring that antenna up into the area where the radio is. I plugged it into the radio and it worked on the first try (I think I needed a radio shack adapter to do it). You get lousy reception without an exterior antenna.
One really nice feature was we used a car stereo with an aux out connector, so I can plug my iPod or laptop into it and have quality sound, which is especially nice for when we're watching cable or DVDs on the laptop.
Stephanie
Old 06-10-2006, 08:20 AM   #6
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Here's a picture of the radio installed. You can't see the antenna cable coming in because it's tucked behind the curtain below the cabinet. Same as the aux out cable which is tucked behind the curtain and pulled out to plug into the laptop.
When I installed the Alpine I used the wiring harness stub (I yanked the radio, which was fairly new at the time, out of my Miata because I thought I'd enjoy it more in the trailer), cut off the connector that was to plug into the miata's wiring harness, and created my own little harness in the back with a little slack so I could pull it out to work on it. This was nice because the stub had each wire labled for it's purpose which made it easy to hookup.
Stephanie
Old 06-11-2006, 07:36 PM   #7
Houma , Louisiana
Thank you for your reply. We will certainly take your info into consideration when we get ready to install a radio.
Mimibeth
Old 06-11-2006, 07:37 PM   #8
Houma , Louisiana
Thanks for your information. We'll certainly consider it when we do our installation.
Mimibeth
Old 06-11-2006, 07:39 PM   #9
Houma , Louisiana
Our GT does not have speakers but has the place for them. It does have the outside antenna. I don't know if there is 12VDC wiring in the box or not. Thanks for your help.
Mimibeth
Old 06-11-2006, 07:40 PM   #10
Houma , Louisiana
Stephanie,
Thanks for the information about installing a radio in my GT. Your Caravel looks very similar to our GT. We will certainly consider your info when we get ready to install our system.
Mimibeth
Old 06-12-2006, 07:24 PM   #11
Round on both ends
SafeHarbor's Avatar
1975 28' Argosy 28
Rutledge , Georgia
Just curious... would they have put an outside radio antenna on a trailer that did not have a radio? Historians, anyone?
Lamar
Klaatu barada nikto
Ham Radio in A/S 53flyingcloud Phone, CB & Ham Radio 454 11-25-2017 12:36 AM
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
Installation Rally Pahaska WBCCI Rallies & Events 5 11-20-2002 09:38 AM
Flowmaster RV exhaust system rdm Airstream Motorhome Forums 2 07-09-2002 03:35 PM
Old motorola radio... niftypkg General Interior Topics 1 05-13-2002 09:27 AM
