Old 04-19-2016, 08:41 PM   #1
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
Insignia LED TV's at best buys 12 volt model overview
Went looking for 19" and 24" LED TV for 2005 AS we bought earlier this month. the original unit in bedroom was an old 19" magnavox 12 volt unit with analog only tuner so time to upgrade.
we found both sizes at best buy and noticed the store models were both 12 volt powered with "transformer" that plugs into 120v outlet. I thinking this is great both powered by 12 volts so great when off the grid type camping.
We picked up the 19" at store and 24 was shipped to us. We took the 19" home and checked the wall mount bracket to check for fit.. every looked good but was bummed to see a 120v plug on the back..
the 24" came to the house today and i opened to check it out and get a nice surprise.. it was 12volt powered .
I hooked it up to OTA antenna and get 35 digital stations. Also hooked up 120 /12v transformer to my "Kill o watt" meter.. upon turn on the watts go up to a steady 25watts.. or .035-.036 amps and 42 to 44 VA., which is a nice low draw on batteries.
I might go back to store and check inventory to see if I can find a 19" 12v unit I can swap with.. fingers crossed.
the picture is good and with the smaller screen the 720 resolution looks as good as 1080 on larger set at a lower price. 19" 80.00,, 24" was 139.00 and free shipping.
sound is OK but when we get it hooked up to trailer sound system i should be better for sure.
hope this helps.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 04-19-2016, 09:05 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Ditto, I have had an Insignia Best Buy 21 inch in my trailer for a couple of years. It came with two wire set ups. 110 and 12 volt. It is actually a 12 volt TV. The 110 plug uses a transformer to convert 110 to 12 volt. In operation I can not tell the difference. Excellant picture quality. Mine was an open box special for about 50% off their normal price. I always ask at Best Buy for open box items. Most like the TV seem to not even been actually removed from the box or used in any way.
MICHAEL
Old 04-21-2016, 07:47 AM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I purchased the Insignia 28" LED with DVD combo. The power is a brick that plugs into the wall outlet and a round connector that plugs into the TV. When looking at the specs in the user guide it show Power Input DC 12v 4A. Are you saying I could run this TV directly from the 12v socket if I found a 12v plug that has the same connector to the TV?
Something like this?
http://www.amazon.com/DC-Cord-Cigare.../dp/B008YJ73O0
Kelvin
Old 04-21-2016, 08:12 AM   #4
68Streamline's Avatar
Cerritos , California
I have this TV/DVD combo and I run it off 12V battery. I would advice using a voltage regulator to prevent power surges that might hurt the TV's electronics.
68Streamline is offline   Reply With Quote
Old 04-21-2016, 08:15 AM   #5
KJRitchie's Avatar
2008 25' Classic
Can you post a link to a product is is it something you built?
Several Amazon user reviews state this cable works fine on their Insignia TV.
Here is another one from Amazon. It uses a curley cord cable which I like better.
http://www.amazon.com/HitCar-12-Volt...cr_dp_asin_lnk
Kelvin
Old 04-21-2016, 09:10 AM   #6
timmaah's Avatar
1999 25' Safari
On , the road
I have run two different TV's from 11-14v with no issues. They don't need an exact 12v. The current TV I have had in the Airstream for 2 1/2 years. Use it daily. The back says DC-14. You'll be fine with without a regulator.
Our Adventure.. http://www.watsonswander.com/
timmaah is offline   Reply With Quote
Old 04-21-2016, 12:23 PM   #7
Tincampers's Avatar
Sneedville , Tennessee
How did you get 12v to the tv? I have outlets for 110 and inverter 110.
Tincampers is offline   Reply With Quote
Old 04-21-2016, 12:30 PM   #8
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Newer trailers may not have them
Older trailers (not sure when they stopped providing this) have a cigarette lighter socket in the vicinity of the TV cable jacks. My 2001 Safari 25 and my 2002 Classic 30 slideout both have them.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 04-21-2016, 12:42 PM   #9
KJRitchie's Avatar
2008 25' Classic
My 2008 Classic 25fb has a 12v socket in the TV area. I'm hoping this works because using the 120v/DC brick from my Insignia TV blocks the Leviton wall outlet's USB ports. I installed that outlet last year and would like to be able to use the USB ports again.
Kelvin
Old 04-21-2016, 12:49 PM   #10
AWCHIEF's Avatar
Images: 33
My 2011 Safari has two standard 12 volt outlets located front and rear near the TV cable plugs. I use the rear outlet for a 12 volt fan and the front outlet for a battery monitor gauge. When powering the Tv by 12 volt I remove the battery guage and plug in the TV.
MICHAEL
Old 04-21-2016, 01:06 PM   #11
Tincampers's Avatar
2014 only has one in the cabinet by the door in the rear bedroom model.
Old 04-23-2016, 01:05 AM   #12
noremark's Avatar
1992 32' Excella
Elma , Washington
Images: 12
Lightbulb Was thinking about an inverter.
Thanks again for the Post. I was seriously chewing on an inverter. I just installed an "WIFI Camp Pro" Tube U Antenna for watching Netflix on my laptop attached via a HDMI cable to a 110V 32" TV. Sound comes from the laptop via blue tooth thru a pioneer car stereo attached to the trailer speakers with an added car sub system installed under the jackknife couch.
So I will purchase the Insignia 32" 12v TV to go with the Camp Pro, which also runs off 12V. Now if I Can find a "Blue Ray DVD Smart Player" that runs off 12V I could hard wire the sound straight into the Pioneer. I could add a network router (most run off 12v) That would free up the laptop for surfing while watching a movie.
I am thinking I would run the whole system dedicated 12V with a main power switch to conserve while boondocking.
Any one see any flaws in my thinking? What about a common ground in a setup like this?
If you don't have the time to do it right the first time where you gona find the time to do it a second time.
noremark is offline   Reply With Quote
Old 04-23-2016, 07:00 AM   #13
carl2591's Avatar
2005 31' Classic
On our unit there is a 12v round socket with the cable/TV antenna hookup on the wall in the back bedroom.. (2005 31D Classic) When i pulled it off the wires on socket were only like a 22ga but the wire coming to it was like a 12 ga, much heavier wire capable of more amps.
In the dinette area there is another 12v socket for tv with power button (must be some kind of signal amplifier) and it states no more than 8 amp load.. which is like 800 watts so a 25 watt 12v TV is not going to overload the deal..
No need for surge arrester as the power from a 12v battery is smooth.
SO, yes you can power a 4a 12 volt TV from the wall socket.. if you have one. on my unit all lights, fans, heater, water heater, refrigator have or use 12v.
Kelvin
Carl, Raleigh NC
Old 04-23-2016, 07:04 AM   #14
carl2591's Avatar
2005 31' Classic
UPDATE: Went back to Bestbuy and got to looking at other inventory of the 19" size and found one that shows "DC in" on a picture on box. Bought that one and will be taking the 120v one back..
so now both are 12v powered and I am a "happy camper"
Carl, Raleigh NC
12 volt
Experiences with Insignia (Best Buy Brand) TV? KJRitchie Audio, Video & TV 20 11-02-2014 09:18 PM
Need "Turbo Deisel" insignia Chaplain Kent General Motorhome Topics 1 09-02-2005 08:08 AM
Community karma system info - Overview & FAQs Andy R Our Community 0 05-17-2005 10:58 PM
Ewald buys Venus Ford Andy R Airstream "In the News" 0 11-02-2004 08:15 AM
