Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 06-21-2008, 03:56 PM   #1
JerryMcMunn
Profile:  2008 19' International CCD
Evanston , Illinois
Inside/Outside Speaker Question - 2008 Bambi 10" Ocean Breeze
Greetings,
Our Bambi came with a Sony AM/FM Radio/CD/DVD Player hooked up with a Sony TV & a Sony 10 disk CD Player. The 10 disk player is mounted in the upper forward cabinet above the dinette. Also there are two panels mounted in the curbside wall of the cabinet. One contains a rotary "Speaker Select Switch". The settings are "In", "Out" and "Both". When the switch is in the "In" position, the forward and aft speakers inside the trailer are active. When the switch is in the "Out" position, there is no sound output either inside or outside the trailer.
I am guessing the "Out" position is provided to support a pair of speakers mounted outside the trailer. I am also guessing that when the switch is placed in the "Both" position, both inside and outside speakers will be active. My questions are as follows:
1.) Are the assumptions above correct?
2.) If so, I'm guessing there is some level of pre-wiring for outside speakers. If this correct, where can I gain access to the wires?
3.) Finally, if all of the above is correct, I'm assuming Airstream may have had a route in mind for extending the speaker wires to the outside of the trailer for connection to speakers. If this is correct, does anyone know the route?
4.) If no route was pre-planned, does anyone have any suggestions?
Jerry
Hi-Ho Silver!!
JerryMcMunn is offline   Reply With Quote
Old 06-21-2008, 04:02 PM   #2
JimS
Profile:  2005 30' Classic S/O
Eddy , Texas
We have a 30' Classic which has the same radio set up. There is a plug on the door side of the trailer (down low) which looks like a four plug trailer connection. This is the plug for the outside or "out' speakers. We had to supply our own speakers. I used a 'test' speaker to figure out the hot and ground wires for the speakers. I got a four pole wiring harness from Walmart and used that to connect the speakers.
JimS is offline   Reply With Quote
Old 06-21-2008, 04:11 PM   #3
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
I bought a Advent Wireless speaker from a guy who got it new from AS for $270. It was new and I paid $150 for it. Thought I had a good deal until I saw the same one sell on ebay for $30. Anyway, it consists of a transmitter that hooks into your audio source that the speaker picks up on. The transmitter can also run on 12v but Advent does not tell you that. The transmitter is set up to run on 120. The speaker is set up to run on 120 or 8 D cells. . The frequencies on both the transmitter and speaker have to be tuned in which is a little tricky. The speaker is supposed to work up to 150' away from the transmitter. You can use the speaker as a mono speaker or have 2 set up for stereo. What makes this an official Airstream speaker is you are given an envelope with the AIRSTREAM letters to stick on it.
To quiet slumbers when the day is o'er
And night above me spreads her spangled tent
Lit by the dying cresset of the moon
Ay, That's it I am homesick for the camp/ Boker
Old 06-21-2008, 04:17 PM   #4
JerryMcMunn
Evanston , Illinois
Hi Jim,
Thanks for the answer. I just went outside, inspected and couldn't find it. Can you be more explicit. For example, is it mounted on the vertical side wall of the trailer or on the horizontal underbelly? Also, is it fore or aft of the door?
Jerry
Hi-Ho Silver!!
Old 06-21-2008, 07:16 PM   #5
JimS
Eddy , Texas
My outside speaker connection is just in front of the wheel well, on the door side of the trailer. It has a round plastic cover, but, when you open the cover, there is the four way, flat trailer connection inside. I don't know if they were all wired this way or not. It is hard to see since it is on the black portion of the trailer, below the aluminum sidewall and the cover is black also. Good luck
Old 06-21-2008, 07:47 PM   #6
cosmotini
cosmotini's Avatar
Profile:  2008 27' International CCD FB
Highland , Illinois
Images: 83
Jerry,
I think they dd away with the wired outside speaker setup and went only with the wireless that Lumatic wrote about. Our 2008 has 1 wireless Advent speaker with the same switch configuration for in/both/out.
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 06-21-2008, 10:13 PM   #7
norsea
norsea's Avatar
Profile:  2008 30' Classic
On the road since 2000 , norseaodyssey.com
Wireless speakers vs. wired outside speakers...
Be aware that the way the In/Out/Both switch is wired is extremely important to the way the system functions.
IF (not caps) your trailer was wired for a wireless speaker system that means that the wireless system will be using a floating ground. This means that any use of the jack in the In/Out/Both switch for anything other than something that uses a floating ground could harm your sound system.
See post number 27 in the http://www.airforums.com/forums/f450...reo-36282.html thread.
We are travelers with an attitude. We get to go anywhere, anytime, and have attitudes about what we see and hear.
"Travel is fatal to bigotry, prejudice and being narrow minded."
norsea is offline   Reply With Quote
Old 06-22-2008, 09:09 AM   #8
Lumatic
Lumatic's Avatar
1962 28' Ambassador
I am not sure what a floating ground is but here is my set up:
The sound unit is an aftermarket RV unit. It has connections for 2 sets of speakers and also a headphone jack. My first thought was to hook the Advent transmitter into one of the speaker connections. The instructions were not clear but seemed to imply if you made a hook up this way damage could result. The transmitter just plugs into the headphones jack. The only down side is you can't use both the speakers inside and the wireless at the same time. not a big deal and there is still a little volume that comes out of the inside speakers when using the wireless
By the way, the guy I bought it from sold it because he got a Bose that hooks into his Ipod.
Old 06-25-2008, 07:55 PM   #9
Frank McFee
Profile:  2007 19' Safari SE
Jacksons Gap , Alabama
I have been following this subject with interest since I also have the same A/V set up that JerryMcMunn has but my AS is a 2007 19ft Bambi SE. It was built in 12/06. I would like to connect an external speaker but I have not found the 4-terminal plug that some have mentioned. I searched the bottom of the trailer and especially around the door side but I do not find any plug or cap over a plug. In the overhead cabinet I took off the access panel below the speaker switch and I see 4 wires from the switch (orange,blue,red and pink). The area is full of wires and two black boxes. I notice that the above 4 wires connect to one of these boxes. It is hard to see where the wires are going. Does anyone know where the other end of this speaker wire is located? Hopefully, it was placed where I can get access to it so I can use for an outside speaker connection. I have not called the factory.
Frank
Frank McFee is offline   Reply With Quote
Old 06-30-2008, 05:56 PM   #10
JerryMcMunn
Evanston , Illinois
Frank
I, too, have searched for a connector on the trailer's exterior with no luck. My next step will be to call the factory. Stay tuned.......................
Hi-Ho Silver!!
Old 07-05-2008, 11:26 PM   #11
Westfalia
Westfalia's Avatar
Evergreen , Colorado
Images: 33
Your 08 is probably setup like mine, no external wiring for speakers. Just a jack for the wireless speaker. I disassembled my stereo cabinet to take a peak myself. The wiring for the BOTH and OUT switched circuit runs to a convertor box and back to the LINE OUT jack and that's it.
Chris - Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas!
2008 Dodge Ram 2500 6.7 CTD Mega Cab
1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
Westfalia is offline   Reply With Quote
"OCEAN STATE Rally"- 2008 Titu & Gail WBCCI Rallies 67 09-22-2008 05:49 PM
Question about Ocean Breeze interior Marquette 2007 International CCD 27 03-21-2008 06:47 PM
Ocean Breeze International JimGolden Off Topic Forum 6 04-16-2007 10:53 AM
New 2007 International Ocean Breeze 25FB NeatAirstream The Vendor's Forum 0 12-15-2006 07:39 AM
"Ocean Breeze" decor Pahaska Airstream "In the News" 1 05-27-2006 07:49 AM
